Go Back   Honda-Tech >
> Honda Accord (1990 - 2002)
Old 10-03-2008, 05:37 AM   #1
kornerk12
kornerk12's Avatar
Default Writeup on changing seals under rocker assembly
Im having the dreaded oil in the spark plug hole issue and its not at the valve cover seals. Is there a writeup on changing these ?
kornerk12 is offline Report Post   Reply With Quote
Old 10-03-2008, 05:56 AM   #2
Ross 2.0
Evil before it was cool.
Ross 2.0's Avatar
It's really pretty easy to change cam tower seals. If you can do a valve adjustment you can do the seals. Just take the valve cover off and remove the 8? bolts that attach the valve train to the head. You don't even need to pull the camshaft out.
__________________
My signature
Ross 2.0 is offline Report Post   Reply With Quote
Old 10-03-2008, 07:01 AM   #3
kornerk12
kornerk12's Avatar
Default Re: (Ross 2.0)
oo wow, i thought u needed to pull the cam and belt off. That makes life easier.
Old 10-03-2008, 07:20 AM   #4
Ross 2.0
Ross 2.0's Avatar
Well think about it. The valve train is on top of the camshaft since it's the upper half of the cam bearing. So once you remove that you have the seals right there and the camshaft is sitting happily in it's place. If you're worried about jumping time just get a small spring clamp and put it on the cam so the belt won't move.
__________________
My signature
Old 11-07-2009, 06:25 AM   #5
brucepick
brucepick's Avatar
Default Re: Writeup on changing seals under rocker assembly
Does that require a valve adjustment after putting the rocker assy back or does the adjustment stay just as it was, after you put it all back together??
[[OK, I'm semi-educated on this.
I did a valve adjustment on my Civic once and on other cars eons ago.
So, to change the tube seals on our Accord, I pull the valve cover and then just remove the hold-down screws for the rocker assembly? That exposes the leaky tube seals??]]
__________________
Driving a '97 Civic HX 5-spd: VTEC-E Lean Burn coupe.
Wifemobile: '96 Accord 5-spd, 4-dr, F22B2
brucepick is offline Report Post   Reply With Quote
Old 11-07-2009, 09:58 AM   #6
fleetw00d
fleetw00d's Avatar
It is recommended that you back off the valve adjusting screws before removing the rocker assembl; then just readjust them all after reinstallation. Not backing them off may adversely affect the preload on the hold down bolts when reassembling.
__________________
90 LX 4dr 5 spd 297,000+ / 93 LX 4dr 5 spd 106,000 / 93 EX 2dr auto 151,000 / 93 LX Wagon auto 150,000
fleetw00d is online now Report Post   Reply With Quote
Bookmarks
Tags
97, accord, assembly, cam, honda, rocker, seals, tower
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
