| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Used Cars | Garage | Vendor Directory |
#26 | |||||
__________________
2008 Fiji Blue Pearl FG2//2009 Arctic White Mercedes C300 Vouche list - jdmjim,07SIcpe, junnyx1 Economically proven - "The more you save, the less you have." |
#27 |
There really shouldn't be a difference for map and maf based calibrations. All that means is that the ecu relys on either the map sensor or maf sensor to provide the information required for proper fueling.
When I asked my tuner to give me a conservative tune for engine safety and longevity he told me that he diagrees with that school of thought and said to me that a car is either "tuned" or "not tuned". He said that the difference between running extremely rich at a 10 to 1 a/f ratio and an extremely lean a/f of 14 to 1 would only be around 5 percent different. I said I wasn't worried about extracting every ounce of hp out of the motor so tune it rich and he said don't worry it wouldn't have that much more power if I tuned it lean. So ivtec take some datalogs and see what your a/f's are. If you have an N/A tune the cam tables and vtec tables on the maf/map calibrations should be about the same if not exactly the same so I would find it hard to believe that one was sluggish and one was good. |
#28 | |
Quote:
Cliff notes: a/f between 11.5 and 13 there is less than 1 whp difference 2 degrees of timing 4-5% whp across the board
__________________
88 Si CRX 93 Hatch 07 Si Sedan 09 Si Sedan |
#29 | |
Quote:
trust me, there was a considerable difference in bottom end power.
__________________
#30 |
what about tuning a k24a2 motor in a 07 si? can that be done with flashpro?
__________________
Need a trans rebuilt, lsd, cams installed, B or K-swap done in Allentown, PA area? PM me. vouch we do good work SEEKSPEED |
#31 |
dont they make a kpro for the k24 motors? If so that would be the better choice.
__________________
07 fiji FG2: XBL/Gamertag: Greg50Lt 1/4mile : 14.473 @97.72 207whp 151.wtq |
#32 |
they have a k24 calibration on flashpro, but its only for a s/c.
__________________
#33 |
So I swtiched my flash from the Injen CAI MAP flash to the MAF flash. Just taking off in 1st gear hitting the gas to release the clutch the car revs totally different. I'm going to give it till mid week on this flash if I don't like it I may have to go back to my previous flash.
__________________
2007 Civic Si Injen/Strup/HKS/HFP/Tein/Hondata Flashpro Dan Keator Photography-Flickr |
#34 |
well look who decided to say hello lol
how u been jj?
__________________
#35 |
Yes.
__________________
#36 |
thank you sir. my 07 4dr si will be getting a 07 tsx motor then.
__________________
#37 |
2008 Honda CivicJoin Date: Sep 2008
Will it fit in the bay? Its pretty cramped as it is.
__________________
You can't stand the heat? Get out of the kitchen. It's not my fault you don't know how to stay in your lane. |
#38 |
it will fit. the tsx motor is only alittle taller.
__________________
#39 | |
Quote:
Thread tools?
__________________
8th Civic Tech Real Technical Resource Brand new RRC manifold on hand $450 shipped Brand new 4.7 K Series final drive set w/ bearing on hand $225 shipped |
#40 |
Well after running the Injen CAI w. race header MAF map for almost 48 hours I'm getting used to it a little better. It deff has less lag down low than the MAP map I used before.
__________________
#41 | |
Quote:
see what did i tell you?? and thanks ajp for thinking i was crazy when i was correct the whole time.
__________________
#42 | |
Quote:
the only thing i feel is that this reflash has a little more rev hang than the previous reflash did.
__________________
#43 |
haha ok man relax....Well it shouldn't be different. It's just the ECU relying on different sensors to provide the information for fueling. And Hondata and tuners say it's easier to make a good tune when using the MAP sensor, but maybe that's for just when tuning for forced induction.....I dunno
#44 | |
Quote:
apparently you havent driven with fp on a maf and map tune. theres a considerable difference.
__________________
#45 |
so why wouldn't Honda do this from the factory? does it sacrifice some reliability? (talking 200K miles compaired to 250-300+)
__________________
2008 Fiji Blue FG2 |
#46 |
^what do you mean?
__________________
#47 |
This popped up in my "Videos Picked For You" section on Youtube.
Found it pretty interesing.
__________________
#48 |
2008 Honda CivicJoin Date: Jun 2008
Nice find Fiji.
#49 |
so when i end up getting this i need to use a afm/maf flash in order to keep the oil life meter. it will be awhile but i am trying to get my reading in for now.
__________________
fourdoormafia y0! Your stang might be good in a straight line, however most of the roads in the world are curvy, like my wife. |
#50 |
new sound clips from tonight! turn your speakers up!!
__________________
| Bookmarks |
| Tags |
| accessport, control, driving, flash, flashpro, honda, hondata, hondatech, idle, impressions, launch, pro, s2000, set, si |
