| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | My Recent Topics | My Notes | Used Cars | Garage | Vendor Directory |
#1 | |||||
__________________
-93 purple dx coupe b16a3, 88 crx si built/boosted dohc zc, 07 r6 with bolt ons ~~~~ myspace.com/iheartboost06 add it! JUMP OFF A BRIDGE JUAN! NOW!! |
#2 |
You can't run the OBD1 dizzy with an OBD0 ECU.
__________________
. o 0 0_o 0 o . |
#3 |
y not? ive heard of people doing it before
__________________
#4 |
Oh really?
And how many of them ran correctly? The reluctor ring inside the distributor has a different number of teeth. If you run the OBD-1 on your OBD-0 ECU then you get the wrong pulses to the ECU... and it will never run right.
__________________
. o 0 0_o 0 o . |
#5 |
Exactly...
#6 |
i called rywire and u are right my friend.. thanks.. it runs but just throws thos codes.. and when i mean runs, it barely runs lol
__________________
#7 |
wat about running obd1 injectors just spliced in?
__________________
#8 |
Are you running a resistor box or no?
#9 |
na.. i took the 5 wires that lead to the resistor box and put them all together
__________________
#10 |
Then yes, you can use OBD-1 injectors.
#11 |
you should really just get you a obd0 to obd1 jumper. for the dizzy, and ecu. and bam! problem solved. wire in your vtec. and bam jdm d15b vtec running like a champ.
#12 |
i would if it was my car trust me.. if u saw my cars u would see there crazy clean.. but this is my friends whip and he is on a big budget so hes tryin to cheap it out.. :/
__________________
#13 |
half a**ed equals half fast, I just had to fix a harness for a guy that has all of the wires twisted together and heat shrinked, took me six hours to un cluster that charlie foxtrot.
| Bookmarks |
| Tags |
| distributor, honda, mpfi, obd0ecu, obd1, run, swap |
