Go Back   Honda-Tech >
> Honda Prelude
Old 11-04-2009, 03:32 PM   #26
THC07
THC07's Avatar
Send a message via AIM to THC07
Default Re: hondata s300
Quote:
Originally Posted by HdeucedeuceA View Post
Also to be noted, is that a P28 doesn't have a knock sensor nor can it control the butterfly valves in the intake manifold.
fyi you can use IABs with the p28. when you chip the ecu you just have more work to do on the board.
__________________
Euro H23V EJ8 10:1 No track times yet guessing high 11's with n2o, and a lot of it.
---K.E.C--- Full ECU service, PM!
http://hondamarketplace.com/showthread.php?t=2660478
THC07 is offline Report Post   Reply With Quote
Old 11-04-2009, 03:42 PM   #27
HdeucedeuceA
HdeucedeuceA's Avatar
Quote:
I ment the computer in general. Yes you can add it but it wan't originally their.
__________________
Chaz
92 Prelude Si; soon to be Mugen kitted
HdeucedeuceA is offline Report Post   Reply With Quote
Old 11-04-2009, 09:21 PM   #28
btwentyna
I have no clue what you're trying to say. If it's tuning related, RESEARCH RESEARCH RESEARCH.
a wideband,... but alright
btwentyna is offline Report Post   Reply With Quote
Old 11-04-2009, 11:34 PM   #29
HdeucedeuceA
Quote:
A wideband is a sensor, similar to an oxygen sensor, that measures a broad range of A/F. They don't come on the car, you have to buy and install one.
__________________
Chaz
Old 11-04-2009, 11:45 PM   #30
btwentyna
the wideband,... i dont kno which one i have.
and i am looking for what it is and found;
Wideband is more accurate for determine how lean/rich you are running
Your car stock has 2 narrowband O2 sensors, these sensors operate between 0 and 1000 mv ... however they are only accurate at or around 14.7:1 Air Fuel Ratio
The further you go away from 14.7:1 (either direction) the less and less accurate they are
Wideband operates from 0 to 5 volts and I think has a useable range of 10-20 Air Fuel Ratio? It is VERY accurate ...
So by logging the AFR using an accurate wideband you can more easily and safely dial the tune in
and
The wideband will alow you to get real time on the road air fuel readings. This allows for more precise programming of the PCM.
Old 11-05-2009, 12:12 AM   #31
jnv255
jnv255's Avatar
My tuner uses his own Wideband, they take mine out and plug his in... Get it to a tuner and let him tune it, spend 100$ on a tune or a 1000$ when it blows.
I run an Innovate LC-1, if that helps..
__________________
643hp on wastegate
Another broke 11B (Infantry)
jnv255 is offline Report Post   Reply With Quote
Old 11-05-2009, 10:27 PM   #32
HdeucedeuceA
I'm just getting into tuning and find it fun. If you don't want to tune then what ever. If I blow my engine I'll just drop another one in and hopfully learn from my mistakes. And I run a PLX. This is what Hondata recommends.
Also, OBD2 cars have 2 O2 sensors and OBD1 only has one.
__________________
Chaz
Old 11-05-2009, 10:43 PM   #33
jnv255
jnv255's Avatar
i wasent taking about you, the other guy dont seem to know much about it
__________________
643hp on wastegate
Bookmarks
Tags
98, ecu, h22, hondata, install, installed, map, maps, p13, p28, p72, prelude, s300, sale, wideband
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
