Does a 92 civic si have a transmission fluid dipstick?
Hello, im trying to check if my transmission fluid level is low, but I cant seem to find the a dipstick for it, ive search and some people say it does have a dipstick, some said it doesnt. so I thought what better place than here to ask.
Re: Does a 92 civic si have a transmission fluid dipstick?
if its a manual then no, the way you check with a manual is theres a plug on the passenger side...what ive been told you pull the plug and if it drips out on a level surface its fine....correct me if im wrong ppl
sounds right to me. i think the Si was only available in a manual so there is no dipstick, and checking it sounds right.
318 Curves, 11 miles
No dipstick on manual transmission. According to the Helms, the way to check it is to park on a level surface, remove the fill bolt on the side of the transmission, and stick your pinky in. If you can touch fluid you're just right. If fluid runs out, you're high.
yea that correct.
just for reference, that plug is right above/a lil behind the passenger axle input into the trans.
its a 17mm. ;]
its a 17mm. ;]
Sk22000
Honda Civic (2016 - Current)
05-12-2018 04:39 AM
rolledthatho
13
01-25-2011 09:42 PM
kp3ft
Classic Hondas
12-15-2008 03:17 PM
Heat
09-07-2005 12:10 AM
