Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
View Poll Results: 5-lug worth it?
Yes 140 38.57%
No 223 61.43%
Voters: 363. You may not vote on this poll
submit to reddit
Old 07-07-2009, 04:11 AM   #26
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
iTrader Rating: (0)
Default Re: Is a 5-lug conversion worth it?
Quote:
Originally Posted by nsxtasy View Post
Nope, the 5 lugs won't do anything for you.
As for bigger brakes (regardless of the number of lugs), keep in mind that no brakes will give you any greater stopping power than your tires can handle. If you want better stopping power on the street, the first step to take is to get better, stickier tires. A more aggressive pad compound would be the second step. And a higher temperature brake fluid is the third step to take. And none of these steps requires changing the calipers or rotors. Do all of these things, and you'll probably find that you don't need to change the calipers or rotors at all. Not for street use, anyway.
If you track your car, the big reason for big brakes is to manage the heat of the brakes, more so than for stopping power - IOW to prevent the brakes from getting too hot and cracking rotors too often. And even on the track, your best bet is to take other, less drastic measures first (e.g. pads designed for the racetrack), and only upgrade calipers/rotors if you're still having problems.
I thought you found the stock 262mm brakes on your GSR were inadequate for the repeated braking cycles of HPDEs.
__________________
404: Care not found.
Dogginator is offline   Reply With Quote
Old 07-07-2009, 05:02 AM   #27
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
Quote:
Originally Posted by shwanC View Post
The CTR/ITR brakes do weigh alot more than the factory brakes. With that little bit more meat, there is less brake fade, which no one has mentioned yet. Also, the fact that having a facotry brake setup lets you pick up aftermarker parts from most part stores.
A trip to autozone or napa for a rebuild kit for Wilwood 4-pot calipers would be a waste. Factory 98-spec ITR on the other hand...
I just can't get over people saying its just for looks. Wow.
Did you check the links I posted above? You can get ITR-spec brakes while still retaining your stock hubs for less money than a full 5-lug conversion.
As for wheel choice, I guarantee there are just as many choices in 4x100 as there are in 5x114.3. Wheel choice isn't really a valid justification for converting to 5-lug.
If you get a smoking price on it, and you know that the parts ARE NOT STOLEN, then by all means go for it. But in most cases, you can get the same braking power and have the same wheel choices for less money.
__________________
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 07-07-2009, 05:11 AM   #28
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
iTrader Rating: (0)
A car with a 5-lug swap is a greater target for theft.
__________________
Old 07-07-2009, 06:21 AM   #29
nsxtasy
H-T Order of Merit
Garage is empty, add now
iTrader Rating: (0)
Quote:
They're perfectly fine for street use. And for the track, the stock brakes give adequate stopping power; just to repeat myself, the issue with track use is heat management, not stopping power (and heat management is not simply a matter of rotor size).
However, the OP has not mentioned any intention of using his car on the track. For street use - his apparent intention - there is no performance reason to get bigger brakes. Of course, you can still do it if your objective is for the bling bling.
nsxtasy is offline   Reply With Quote
Old 07-07-2009, 06:57 AM   #30
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
If you just want the ITR-style wheels, there are also 4-lug ITR replicas out there.
__________________
member #0001
Old 07-07-2009, 10:01 AM   #31
deejaylewlew
iTrader Rating: (0)
5 lug = pointless for the average dd
deejaylewlew is offline   Reply With Quote
Old 07-07-2009, 12:27 PM   #32
racebum
2002 Chevrolet Corvette
racebum's Avatar
iTrader Rating: (0)
Racebum
Send a message via AIM to racebum Send a message via Yahoo to racebum
Quote:
Originally Posted by PatrickGSR94 View Post
Integra 11" kit $630: http://www.fastbrakes.com/ProductDet...DC+11+inch+kit
Or for $120 more you can go up to 12.2" rotors with 4-pot Wilwood calipers (requires 16" or larger wheels): http://www.fastbrakes.com/ProductDet...tegra+140+6163
the fastbrake kit can be done for less if you're resourceful
trade in gsr calipers for legend/itr caliper remans $120
axxis ultimate pads $75
mill calipers $40
prelude vtec blank rotors $80
$315 total which is half of what FB wants. drilling the rotors yourself isn't hard. you can even be a little sloppy since they are hub centric
__________________
Mountain View Carpet Care also found at carpet cleaning beaverton Do you own a turbo honda? see turboinstall.net
racebum is offline   Reply With Quote
Old 07-07-2009, 02:05 PM   #33
maxogsr
maxogsr's Avatar
iTrader Rating: (0)
x2... I track my car for 5 years now on 4 studs and never, ever had issues of any kind... like nsxtasy said, it's all about tires, brake oil and pads... And remember, the later you brake on track, less heat you'll built... brake harder and later is the key...
__________________
Have you hug your race car today?
maxogsr is offline   Reply With Quote
Old 07-07-2009, 02:06 PM   #34
Jimmy
Global Moderator
1994 Acura Integra
Jimmy's Avatar
iTrader Rating: (2)
dangjimmy
Quote:
Originally Posted by jhammond_82 View Post
i don't think so. stockers work just fine for me. and if you like to rotate your own tires, just think, thats another 4 lugnuts to loosen and tighten!
Quote:
Originally Posted by dntnedvtec View Post
LOL, especially if you do it by hand...
IMO, it opens up your world for a different selection of rims. (5-lug compared to 4-lugs.) I wouldn't get it though...to pricey. I also, nevermind. ShwanC beat me to it with weight.
I can't believe you guys are complaining about an extra lug on each wheel.
Lazy!
__________________
2004 Acura TL - Daily
1994 Integra RS - Track car
instagram: @jimmydudley
My build thread: 94 Integra RS sloow build-up
Quote:
Originally Posted by Danza
The Man can't hold you down when you're flossing the bright green belts dawg
Jimmy is offline   Reply With Quote
Old 07-07-2009, 07:56 PM   #35
Rediness_code
iTrader Rating: (0)
Not worth it, I love my 4 lug
__________________
all mota, todo el dia.
Rediness_code is offline   Reply With Quote
Old 07-07-2009, 08:30 PM   #36
dntnedvtec
dntnedvtec's Avatar
iTrader Rating: (0)
Quote:
Lazy!
yeah, your probably right. But in my defense, my back hurts!!
__________________
Quote:
Originally Posted by diablo2184 View Post
is it better to reply or bump an old thread or create a new one? cuz some people go crazy when someone makes a new one and they say to search
dntnedvtec is offline   Reply With Quote
Old 07-08-2009, 02:01 AM   #37
R00teg
iTrader Rating: (0)
Quote:
Originally Posted by steveo135 View Post
rear control arms are different on itr's compared to all other integras (gsr\ls\gs) and by swapping the control arm for the conversion you would probably need new rear shocks
it's not worth it
/thread
you got it reverse man, if you utilize the ITR or CTR rear stock shocks/struts then you would need the ITR LCA. If not, then you would just bolt it on with your original LCA.
R00teg is offline   Reply With Quote
Old 07-10-2009, 05:28 AM   #38
JDMsneakerz
JDMsneakerz's Avatar
iTrader Rating: (0)
Send a message via AIM to JDMsneakerz
this info helps me too :D
__________________
CALI moveMENT
JDMsneakerz is offline   Reply With Quote
Old 07-10-2009, 12:02 PM   #39
vanny_david
vanny_david's Avatar
iTrader Rating: (0)
for $1000 just the 5-lug covnersion
also ITR has a total different suspension assembly than normal teg
I would spend those $$$$ to lighter wheels OR a nice set of 4 or 6-pot wilwood kit
vanny_david is offline   Reply With Quote
Old 07-10-2009, 03:01 PM   #40
keepinitrehaal
keepinitrehaal's Avatar
iTrader Rating: (0)
Send a message via AIM to keepinitrehaal
Would you have to run 16" rims with this setup as well?
__________________
Quote:
Originally Posted by mouab18c1 View Post
so the louder the stronger huh? Hmm maybe i should just hook up my vtec to an amp....i might be 100 times faster...ahahaha
keepinitrehaal is offline   Reply With Quote
Old 07-10-2009, 09:14 PM   #41
boostISbest
boostISbest's Avatar
iTrader Rating: (0)
/thread
x2
__________________
CL9 squad
boostISbest is offline   Reply With Quote
Old 07-10-2009, 09:27 PM   #42
racebum
racebum's Avatar
iTrader Rating: (0)
Racebum
Quote:
no, but as i mentioned before you can do that kit for half the price
__________________
Old 07-10-2009, 09:28 PM   #43
Bro. Darkness
2003 Acura RSX
My Garage
Bro. Darkness's Avatar
iTrader Rating: (0)
Send a message via AIM to Bro. Darkness
Quote:
X2
__________________
92 Integra GS: oops!!!
03 RSX Type S: still tryin to figure it out...
Bro. Darkness is offline   Reply With Quote
Old 07-10-2009, 09:39 PM   #44
hot_rice
hot_rice's Avatar
iTrader Rating: (0)
no HP gain!lol
__________________
91 tahitian green civic hatch
FS:97 integra LS automatic virgin ECU P75(pm me)
hot_rice is offline   Reply With Quote
Old 07-10-2009, 09:39 PM   #45
V8 Eater
iTrader Rating: (0)
I really like the looks of itr 4lugs from earlier itr's,I hate the itr 5lugs we and the jdm's have but the ones that are biggest in size with lots of spokes now that dope!
if the setup comes with rims and the rims I last mentioned I think its worth it,
your getting a nice pair of rims,
better brakes
better suspension
better wh-bearings
and if you ever get sick of it you can easily sell it since its one of those parts that dont loose much value!
I say go for it!
V8 Eater is offline   Reply With Quote
Old 07-23-2009, 05:07 PM   #46
4doorteggy
iTrader Rating: (0)
Quote:
Originally Posted by NeverLift View Post
i once thought of doing the conversion but i didnt want to anymore...why? because i dont track my car and it was just for looks. if you want to do it for looks then be my guess. for some, its a waste of money and for others, its worth it. function or fashion... you pick.
this
4doorteggy is offline   Reply With Quote
Old 07-24-2009, 06:10 AM   #47
94DCLS
94DCLS's Avatar
iTrader Rating: (0)
Since i own a stock 95 dx and a 94 boosted integra ls, would it be worth it to put my integra breaks from all four corners on the civic and then go 5 lug?
94DCLS is offline   Reply With Quote
Old 07-24-2009, 11:50 AM   #48
Queensfinest88
Queensfinest88's Avatar
iTrader Rating: (0)
Send a message via AIM to Queensfinest88
If i was gonna do some circuit racing YES for daily driving and an unmodified car NO!
Besides having ITR setup only increases the chances of peoples eyes on your car and waiting to scheme on you!
I wouldnt recommend it as much as i Love 5 Lug setups
Queensfinest88 is offline   Reply With Quote
Old 07-24-2009, 07:24 PM   #49
PaulMc
PaulMc's Avatar
iTrader Rating: (0)
The only people who are against 5-lug are the people who are to broke to afford it. ITR/CTR 5-lug is deffinitly worth it for all reasons function/form wise, and also just looks better.
__________________
2001 Acura Integra Type R #26
PaulMc is offline   Reply With Quote
Old 07-24-2009, 07:26 PM   #50
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
iTrader Rating: (0)
Quote:
I'm against it and can afford it many times over.
__________________
submit to reddit
Tags
98, acura, advantages, civic, conversion, del, em1, honda, integra, itr, kit, lug, sol, tl, vancouver, wwwwhtwheelscom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
