Code P0108 MAP Help
Old 04-21-2009, 07:28 PM
nello a.'s Avatar
Default Code P0108 MAP Help
1996 ls integra.
getting this code. car chokes sometimes when throttle input is light off the line. has a slight miss also.
previous owner had a switch wired to the map for some reason. ripped that **** out and reattached the plug in stock formation. i should have looked at it more closely before i removed it i guess.
plan on slapping on another sensor.
if this does not fix the problem, does anyone know how to wire the map directly to the ecu?
my pinout says plug D, pins 3 and 4 are "map" and "sensor voltage for map" respectively.
to avoid confusion and my ignorance, could someone show me the plug colors that go to these 2 wires at the ecu? and, can i run the third map plug wire to any good ground.? or, does it have to run to one of the sensor grounds at the ecu for some crazy reason?
thanks in advance.
i just finished putting a z6 into a 96 coupe. i finally got it to run with no cels and pass safety inspection. it was a wiring nightmare for me. i am not good at electrical stuff. it scares me into thinking i am going to burn something up.
Old 04-22-2009, 12:38 PM
nello a.'s Avatar
Default Re: Code P0108 MAP Help
no one?
Old 04-22-2009, 10:42 PM
nello a.'s Avatar
guess i should ask which wheels or lip looks best on my car?
bet i would get 100 replies in a day.
"honda-appearanceshitonmyhonda.com" = new honda-tech member nickname for the site
Old 04-22-2009, 11:01 PM
jdm_bones's Avatar
I would help you if I had diagrams in front of me but I don't, but I hear you on the whole 100 replys for wheels and crap...last time I checked this was called honda tech, not honda style....
Old 04-23-2009, 04:29 AM
redflaredcrx90's Avatar
no need to wire direct to ecu find the map wire peel back black wraping and make sure the wire matching. stock yellow /wred,green/white and white for the map. start at the fire wall
Old 04-24-2009, 08:09 PM
nello a.'s Avatar
it would take alot less time to wire direct to the ecu, if someone had the diagrams. my only helms is for an obd1 car. no ecu wiring help there.
mr2turbo007
04-23-2012 06:22 PM
msinsky14
11-25-2008 05:57 PM
88crxdxfastwhip
03-13-2006 06:35 PM
soulrider4ever
10-27-2005 04:12 AM
MugenizedR
11-01-2003 03:43 PM
Quick Reply: Code P0108 MAP Help
