| Welcome to Honda-Tech! | ||
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today! |
#1 |
Garage is empty, add now
When an amplifier manufacturer gives an RMS rating for bridged mode, do you assume that it is at 4ohms if unspecified?
The reason I ask is because my 2 channel amplifier (Power Acoustik BAMF 1250) has a rating of 560 Watts Bridged, but does not specify at what impedance. However, it says it recommends 4-8 ohms only in bridged mode. After hooking my 4ohm DVC Rockford Fosgate subwoofer (wired at 8 ohms), it seems a little weak (also sounds distant) even though it's RMS is 400 watts. I'm assuming at 8 ohms it's only getting 280 watts bridged. I know I will get more power by running this subwoofer at 2 ohms stereo rather than 8 ohms bridged/mono, but are there any pros and/or cons of wiring it this way? I've searched and can't find much info on 8 ohm bridged vs 2 ohm stereo, only 8ohm brigded vs 4ohm stereo which is not applicable to this subwoofer. |
#2 |
This is power acoustik specs page for this amp . pdf. @ the bottom of page 5
http://www.poweracoustik.com/p...8.pdf Bridged 2 ohms is 560 rms. It is 2 ohms to answer your question. 2 ohms is 280x2 4 ohms is 220x2 |
#3 |
I have that same spec chart here in the owner's manual. I guess I didn't think to do the addition myself. It claims it's only 2 ohm stable in stereo, so why would they say 560 watts at 2 ohms bridged when they recommend 4-8 ohms bridged?
I'd imagine it wouldn't be a good idea to bridge 2 ohms with this amp. Even though they give the power rating for doing so. Pretty misleading. So really at 8ohms bridged I am only getting 187 watts, correct? Modified by MilanoLude at 3:55 PM 8/7/2008 Modified by MilanoLude at 3:55 PM 8/7/2008 |
#4 |
Being a 2 channel amp they assume you will be using it for component speakers. And in that case 4-8 is great for sound quality. It allows the speakers to produce a more clean sound for vocals and mid/high sounds.
When a subwoofer is connected to an amp at 2 ohms it is less of a sound issue and more of a power issue vs. wired at 4 ohms. I don't see a problem with using this amp at 2 ohms bridged. It all depends on your subwoofers though. Probably around 187, yes. What subs do you have and what kind of box? |
#5 |
I have one (RFP-1212) 12" Rockford Fosgate Punch DVC 2x4 ohm subwoofer in a sealed box filled with polyfill that is a little smaller than the recommended enclosure size. It's one of their older models, but all the specs are archived in this pdf: http://www.rockfordfosgate.com...n.pdf
400 watts RMS 800 watts Peak I actually had that particular subwoofer connected to a RF Punch 75.2 amplifier , it was bridged at 2 ohms and worked for many years, but it took a crap recently so I replaced all the wiring and amplifier with something new. It ran pretty hot at 2 ohms, it would overheat sometimes during moderate length trips on hot days. For that amp the specs are 37.5 x 2 @ 4 ohms 75 x 2 @ 2 ohms 150 bridged @ 4 ohms I figured this new amplifier would be better matched with the subwoofer (closer to 400 watts RMS @ 8 ohms) , but I didn't check that the 560 watts of the power acoustik was at 2 ohms. I just assumed 4 ohms. . . and you know what assuming does. |
#6 |
You have 2 options.
1 - 8 ohm (series) bridged 374watts rms of power. Cannot max out the sub but will have better sound quality. Not as stressful for the equipment. Since the box is a little small I would recommend this route. 2 - 2 ohm (parallel) bridged 560watts rms power. Will max out sub, but amp will need to be turned down to match the subs needs. Stand a chance of burning something up especially if played at high volume for a long time. |
| Tags |
| 1212, 752, amp, bridged, dvc, fosgate, mode, ohm, ohms, punch, rfp, rockford, specs, stable, stereo |
