Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Accord (1990 - 2002)
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 07-01-2006, 01:46 AM   #1
Stevenm122084
Garage is empty, add now
iTrader Rating: (0)
Send a message via AIM to Stevenm122084
Default Intalling Header, Stripped a Nut!
If you are one of those foo's who stripped a nut while trying to removed the stock exhaust manifold, such as I, yeah, you know which one it is... here is the how to remove guide:
1. Round the edges with a 14mm socket (the one that is supposed to fit) and continue doing this untill it is perfectly round.
2. Take a Dremel with a cutting wheel and cut the lower half of the manifold(the pipe... not the hard cast...) and cut at it till you break 5 wheels.. and tighten the dremel bit too tight where you can remove it and you have to take it apart and some how magicly get it loose.(by the way, this is irrelivent but nessasary part of the removal)
3. Take the same bit and cut at the nut sideways because the frame is in the way and you can only cut from one angle. Continue to do this untill you break 5 more cutting wheels.
4. Again, take a 14 mm socket (try muliple ones, because there sizes may very) and round the edges some more!
5. Take a masive dremel knock off(roto something....) and put in a huge drill bit that happens to have a end that fits it...(I'm talkin half inch drill bit... you'll find em that'll fit...trust me). From the top now, manage to squeeze it between the A/C line and one of the fans(which you must remove for some strange reason...) then press as hard as you can untill you slide off what you are drilling and put it streight into the radiator untill your drill has done enough damage where the radiator leaks.
6. Take a vice grip and get it on as tight as you can get it, then take many wrenches of diffrent sizes and try to pull it around the vice grip handle to turn the bolt. Have a helper to tell you what you face looks like as you pull your hardest. This will round more of the edge, but is a very nessasary step which leads to the final step.
7. Take a 13mm (yes... its the wrong size) and a extention bar and hammer(carfull... dont break the socket) untill it sides into place. It will fit.. because of all the damage you have done do the nut. Pull as hard as you can with a socket wrench and TA-DA! You removed the very frustrating nut!!
8. After 5 pain staking hours of pure frustration, take your nut(and the socket, because you'll have an even harder time removed those two) and put it in a plastic display case, and hang it on the wall in your bedroom and marvel at its amazing glory!
Modified by Stevenm122084 at 3:22 AM 7/1/2006
Stevenm122084 is offline   Reply With Quote
Old 07-01-2006, 02:28 AM   #2
pos_cd5
pos_cd5's Avatar
iTrader Rating: (0)
Send a message via AIM to pos_cd5
Default Re: Intalling Header, Stripped a Nut! (Stevenm122084)
why do all that when you can go buy a bolt-out socket?
pos_cd5 is offline   Reply With Quote
Old 07-01-2006, 02:35 AM   #3
cavy95
cavy95's Avatar
iTrader Rating: (0)
two words- vice grips
cavy95 is offline   Reply With Quote
Old 07-01-2006, 04:52 AM   #4
teamlegacy
iTrader Rating: (0)
Send a message via AIM to teamlegacy
Default Re: Intalling Header, Stripped a Nut! (cavy95)
Were those instructions to expletive up a nut or get it out?
__________________
'93 Accord LX Sedan - New Project
'92 Accord DX Sedan - Project CRUSHED
'07 Trailblazer SS - 400hp - FOR SALE
teamlegacy is offline   Reply With Quote
Old 07-01-2006, 10:30 AM   #5
95lxcoupe
95lxcoupe's Avatar
iTrader Rating: (0)
Send a message via AIM to 95lxcoupe
Default Re: Intalling Header, Stripped a Nut! (teamlegacy)
lol im assuming he had the problem of a stripped nut, and tried all that until he finally got it off.
very sarcastic post, i thought it was funny. +1 for you Click the image to open in full size.
__________________
Team 2 Door Accord - Member #1 [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
95lxcoupe is offline   Reply With Quote
Old 07-01-2006, 09:09 PM   #6
Stevenm122084
iTrader Rating: (0)
Thanks for understanding the humor in it, even reading it back myself I got a laugh. Some people are just way to serious, and they have problems reading too. I love how they tell you to try something that if they read the whole post would have realized I already did it.
submit to reddit
Tags
cut, dremel, exhaust, exhust, header, headers, honda, manifold, nut, nuts, remove, removing, socket, striped, stripped, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
