Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 07-26-2002, 08:08 AM   #1
aqttran
Garage is empty, add now
aqttran's Avatar
iTrader Rating: (0)
Default Timing belt symptoms?
Does anyone knows what are the symptoms of the timing belt failure? Got an 89 Accord LXi. Engine stopped suddenly on the highway and never start up again. Dealer said it may be the timing belt. Want to get a second opinion. Thanks
aqttran is offline   Reply With Quote
Old 07-26-2002, 08:32 AM   #2
Chiovnidca
Chiovnidca's Avatar
iTrader Rating: (0)
Default Re: Timing belt symptoms? (aqttran)
That's a pretty good symptom. If you don't beleive the dealer, ask to see it before you authorize any work.
__________________
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline   Reply With Quote
Old 07-26-2002, 09:32 AM   #3
Power1Pete
Power1Pete's Avatar
iTrader Rating: (0)
Send a message via AIM to Power1Pete
sounds like it is. btw, when was the last time you change your timing belt? they usually last around 60K miles.
__________________
98 Civic LX - FBP
Power1Pete is offline   Reply With Quote
Old 07-26-2002, 01:58 PM   #4
88_SC_CRX_Si
New User
iTrader Rating: (0)
There is a good possiabilty that some valve damage occured, depending on what rpm you were at. Sooo, that way you won't be too surprized, about the bill you get for replacing the bent ones.....
__________________
[i][b]"Noth'in like Induction..." [img]http://rely.net/~htimages/smile/emwink.gif[/img][/i][/b]
[i]88' CRX Si - JRSC @ 6psi Z6 Mini-Me.....
ZYDNE Gold, NOS Dry 20 Shot, JR Liquid InterCooling System
Endyn/Bosch FP, CarTech FMU, B&M Command Flo
AutoMeter - Phantom FP, A/F, Boost, N2O gauges & pods, B&M FP Set
ARP HS Kit, AEM Pads, 87' HF Alum Drums, DYI CAI[/i]
88_SC_CRX_Si is offline   Reply With Quote
Old 07-26-2002, 08:19 PM   #5
BreakStuff
New User
iTrader Rating: (0)
ok girls.. heres a tip...
remove the oil filler cap on the valve cover.. shine a flashlight in the hole and visually see if the valvetrain is moving while cranking the motor..
no movement = broken T-Belt..
BreakStuff is offline   Reply With Quote
submit to reddit
Tags
1990, 2001, 2002, accord, back, belt, change, failure, honda, hondatech, signs, symptom, symptoms, sypmtoms, timer, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
