Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 03-20-2002, 05:25 AM   #26
Regular Series
Garage is empty, add now
Regular Series's Avatar
iTrader Rating: (0)
Send a message via AIM to Regular Series
Default Re: PCV Valve symptoms (eh-D)
Quote:
My car has 47,XXX and my valve was totally clogged.
My car had only ~40k miles when I checked my PCV valve, and it was completely non-functional! It produced not a single rattle. Click the image to open in full size.
Not to mention that when I got a new valve installed it made a very noticeable noise when I started the car.
[Modified by risingson77, 9:25 AM 3/20/2002]
__________________
"Your winky is going places http://images.honda-tech.com/set1/smile/emthup.gif" -RUBZERK
"Yeah guys, It ain't that bad. It's like A/C in the summer time: sure it's good to have, but it slows you down. " -len, on having a woman in your life
Regular Series is offline   Reply With Quote
Old 03-20-2002, 05:49 AM   #27
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
Default Re: PCV Valve symptoms (risingson77)
I sure wish I could get my hand down around where the valve is to make sure it's fully seated. When I changed mine I had a hell of a time, and I don't think I got it seated all the way in the top of the separator. Click the image to open in full size.
__________________
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 03-20-2002, 06:09 AM   #28
Fooser
iTrader Rating: (0)
Default Re: PCV Valve symptoms (PatrickGSR94)
Since I have a GSR how would I get to it? Ok put it this way. How would a mechanic get to the valve correctly?
__________________
98 Integra GSR
MODS:
* AEM Adjustable Cam Gears (tuning soon...)
* (Red) type R valve cover with moon cuts
* AEM Cold Air Intake
* Comptech Headers 4-2-1
* Random Tech. High flow Cat.
* Greddy Exhaust (Evo)
* H&R full coilover and shock setup
* Ignalls Front Camber kit & Specialty Products rear kit
* Eagle 160 Series 17" Rims
* Kumho Ecsta Supra Tires
* Mesh Bumper Grill
* Limo Tint w/black vinyl on the Dot matrix
Fooser is offline   Reply With Quote
Old 03-20-2002, 06:20 AM   #29
BSQ
BSQ's Avatar
iTrader Rating: (0)
I would suggest taking a long screwdriver and push down on the sides of the PCV valve. This should allow you to make sure that the PCV valve is fully seated.
__________________
Bret - '94 GS-R
http://www.geocities.com/bretq (or my mirror site http://www.geocities.com/bretq2)
BSQ is offline   Reply With Quote
Old 03-20-2002, 06:25 AM   #30
BSQ
BSQ's Avatar
iTrader Rating: (0)
Default Re: PCV Valve symptoms (Fooser)
When I installed my oil catch can, I finally had to remove the throttle body to gain access to the PCV valve. I actually worked out nice, because I was then able to spray some throttle body cleaner on the backside of the throttle body plate and inside of the intake manifold to try to clean up some of the oily "gunk" which had accumulated.
__________________
Bret - '94 GS-R
Old 03-20-2002, 06:25 AM   #31
Fooser
iTrader Rating: (0)
Default Re: PCV Valve symptoms (BSQ)
Ok someone answer this for me. Does the valve just pull out? Or do I have to unscrew it? Any tips would be appreciated. I think I'm just going to replace it since its only $3 or so. Not worth chancing a future clog even if its still good.
__________________
98 Integra GSR
MODS:
* Mesh Bumper Grill
Old 03-20-2002, 06:31 AM   #32
Fooser
iTrader Rating: (0)
So what your saying is I have to remove the TB to access it correctly? Thats alot of work. I will take a look myself and see if I can access it.
__________________
98 Integra GSR
MODS:
* Mesh Bumper Grill
Old 03-20-2002, 07:16 AM   #33
eh-D
eh-D's Avatar
iTrader Rating: (0)
The valve pulls out on the big end, and the small end is held on by a clamp. I did not have to remove the throttlebody but I did pull the strut tower brace.
It is a real reach becuase of that clamp, budget a good hour for the first time you do it, and DO NOT attemtp to change the valve when the engine is hot.
__________________
'98 FBP GSR
eh-D is offline   Reply With Quote
Old 03-20-2002, 07:23 AM   #34
Fooser
iTrader Rating: (0)
Are there any special tools required?
__________________
98 Integra GSR
MODS:
* Mesh Bumper Grill
Old 03-20-2002, 07:40 AM   #35
BSQ
BSQ's Avatar
iTrader Rating: (0)
extra small hands Click the image to open in full size.
__________________
Bret - '94 GS-R
Old 03-20-2002, 07:45 AM   #36
Fooser
iTrader Rating: (0)
I see. I guess I will give it a go on Thursday. Dosent seem too hard so I'm going to do it. Do you guys think somewhere like Kragen would have the part? Or should I just go to Acura.
__________________
98 Integra GSR
MODS:
* Mesh Bumper Grill
Old 03-20-2002, 07:47 AM   #37
Regular Series
iTrader Rating: (0)
Pretty much any auto parts store should have one for you.
__________________
Old 03-20-2002, 09:12 AM   #38
Grandprix
iTrader Rating: (0)
BSQ I think you need to put that diagram from TOO on your site. I like when I installed my sway bar there were lots of pictures, but for the catch can install, there are NO pictures of the install, just the final picture.
__________________
Custom trannies are fun!
Grandprix is offline   Reply With Quote
Old 03-20-2002, 09:37 AM   #39
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
I tried that. It doesn't look like the valve is seated all the way, but I couldn't push down on it any more w/ a screwdriver. I was afraid of breaking the valve if I pushed too hard. Any ideas if I could reach the valve from underneath and push it in place, like when I'm changing my oil or something?
__________________
member #0001
Old 03-20-2002, 09:41 AM   #40
Fooser
iTrader Rating: (0)
since its kind of far down maybe you can reach for it from underneath the car.
__________________
98 Integra GSR
MODS:
* Mesh Bumper Grill
Old 03-20-2002, 10:31 AM   #41
BSQ
BSQ's Avatar
iTrader Rating: (0)
Default Re: PCV Valve symptoms (Grandprix)
I agree. I will be reworking my oil catch can installation instructions in the very near future. I will include more pictures and a diagram similiar to one on T.O.O.'s site. I will also include the 2 diagrams from the Helms service manual.
BTW, I just completed reworking (still need to finish tweaking it) my DIY "Icebox" CAI. If you get a chance, check it out and let me know what you think... http://www.geocities.com/bretq/DIY_Icebox_CAI.html .
__________________
Bret - '94 GS-R
Old 03-20-2002, 01:01 PM   #42
bamaTeg
New User
bamaTeg's Avatar
iTrader Rating: (0)
you asked when it is ready for replacement...well in my case on my 95 LS with 100k, my oil light came on and I was about bone dry...it was the pcv valve leaking.
__________________
It takes a big man to cry...and a bigger man to laugh at him.
bamaTeg is offline   Reply With Quote
Old 03-20-2002, 01:07 PM   #43
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
Default Re: PCV Valve symptoms (bamaTeg)
I wasn't aware you could leak oil out of the PCV valve enough to cause the crankcase oil level to drop very much.
__________________
member #0001
Old 03-20-2002, 01:56 PM   #44
Sloth
New User
iTrader Rating: (0)
thats what it looks like seated. sorry my engine is a little dirty here.
Sloth is offline   Reply With Quote
Old 03-20-2002, 04:10 PM   #45
1phatGSR
iTrader Rating: (0)
Default Re: PCV Valve symptoms (Sloth)
could anybody show me where the fuel filter located..sorry don't have a heml's manual.... Click the image to open in full size.
1phatGSR is offline   Reply With Quote
Old 03-20-2002, 05:12 PM   #46
lucas569
lucas569's Avatar
iTrader Rating: (0)
Default Re: PCV Valve symptoms (1phatGSR)
are you joking? if not it's to the right of your battarry Click the image to open in full size.
__________________
WARNING THEIVES: This vehicle is equipped with a page notification alarm system, beware of owner and the KEL-TEC 9mm handgun http://rely.net/~htimages/smile/emwink.gif
lucas569 is offline   Reply With Quote
Old 03-22-2002, 06:28 AM   #47
Fooser
iTrader Rating: (0)
Default Re: PCV Valve symptoms (lucas569)
Ok I just replaced my PCV valve on my 98 GSR. Was actually easy. guess my hands are not that big. Well anways it only took me like 10 minutes to do this. Most of the time was wisted on trying to figure out how to get the hose off the valve. Very easy fix for only $3. with only 32k on my car the stock PCV valve was clogged to the point of nothing moving inside it. All you really need is a long pair of angled needle nose pliers and small flat head screw driver. I had to use the pliers to unhook the clamp which held the valve to the hose. The flat head screw driver was carefully used to help pry the valve from the hose.
Overall I would have to say this is easier then changing an oil filter. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
[Modified by Fooser, 3:31 PM 3/22/2002]
__________________
98 Integra GSR
MODS:
* Mesh Bumper Grill
Old 03-28-2002, 06:13 AM   #48
95GS-R
95GS-R's Avatar
iTrader Rating: (0)
Send a message via AIM to 95GS-R
What were the symptoms that you were experiencing? Was there diminished performance?
95GS-R is offline   Reply With Quote
submit to reddit
Tags
accord, bad, civic, clicking, dirty, faulty, honda, leak, noise, pcv, s2000, supra, symptoms, v6, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
