Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 10-10-2004, 12:30 PM   #1
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
Default symptoms of blown head gasket?
I'm pretty certain mine is fine, but I'm just wanting to make sure...
When I drained the coolant out of my block last weekend to change my water pump, it looked kinda dark. I don't think it was oil, it was probably just dirty, and also because I was looking at it in a bright yellow drain pan, but anyway, what would be symptoms of a blown head gasket besides oil in the coolant? My car runs fine, idles solidly at 750 rpm, acclerates smoothly (especially now that I finally got some axles that don't vibrate), does not consume a drop of oil that I can tell on the dipstick, average 32-34 mpg, regularly get 350-370 miles or more per tank, and all 4 plugs had a normal grayish appearance when I took them out and replaced them last weekend. So what do you think, should I worry about a blown headgasket? Would it cause any of those above things I listed to suffer, like performance or fuel economy?
__________________
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 10-10-2004, 01:13 PM   #2
gsrboi80
Garage is empty, add now
gsrboi80's Avatar
iTrader Rating: (0)
Default Re: symptoms of blown head gasket? (PatrickGSR94)
The car would run shitty and you would see an abundance of white smoke from the exhaust. The dark coolent is probably just crap from your radiator. Not to worry.
gsrboi80 is offline   Reply With Quote
Old 10-10-2004, 02:19 PM   #3
Eddiebx
iTrader Rating: (0)
Send a message via AIM to Eddiebx
yeah if you had oil in ur coolant, u'd know it. don't worry too much just yet. if you really wanna be safe do a leak down test.
__________________
eddie@urbanimport.com <~~~Your D2 Racing Sport Coilover hook up man
Eddiebx is offline   Reply With Quote
Old 10-11-2004, 10:15 AM   #4
psychotic_z
psychotic_z's Avatar
iTrader Rating: (0)
Default Re: (Eddiebx)
Patrick... I just blew my own head gasket about a week or two ago (not sure exactly when it happened) and I realized it this last Thursday. But, you KNEW something was wrong - from the white smoke from the exhaust, the coolant puddling in the exhaust tip ( Click the image to open in full size. ), crappy idle, and rough acceleration...
You can do a leakdown test and/or a compression test to be sure. A compression test was all I needed to be sure mine blew ... 30, 30, 120, 150 Click the image to open in full size. .
__________________
2005 Rally Red Civic EM2 SE
1992 Milano Red Integra RS "Baby"
WAS 7 psi on intercooled custom IHI RHB5 turbo setup
DSM 450cc injectors
Uberdata
Slow
NOW B18A1 w/Custom 2.25 exhaust, short ram intake, Crower 401's, Uberdata, short shifter, removed AC/PS, trunk mounted battery, Exedy clutch, Fidanza flywheel
G2 Teggy's http://images.honda-tech.com/set1/smile/emthup.gif
I wanna catch babies.
psychotic_z is offline   Reply With Quote
Old 10-11-2004, 10:44 AM   #5
Sack Master
Sack Master's Avatar
iTrader Rating: (0)
Send a message via ICQ to Sack Master Send a message via AIM to Sack Master
Default Re: (psychotic_z)
If you had a blown or leaking head gasket you would know it. Either oil in your coolant, coolant in your oil, burning coolant, leaking oil on the outside of the block, overheating. Probably a few other symptoms but probably nothing you just explained.
__________________
Quote:
Originally Posted by warric_k
It could also be the gear ratio in the posi wiper motor fukin up the vtec timer which would make the aluminum hybrid rotor tensioner go lean and you could easily bend your valve under mid to low torque 2nd stage vtec intercooler.
Sack Master is offline   Reply With Quote
Old 10-11-2004, 11:18 AM   #6
marsbike
marsbike's Avatar
Location: Salt Lake City, Chicago at heart, UT or IL, USA
iTrader Rating: (0)
Send a message via AIM to marsbike
you wouldn't be able to drive for more than 15-20 min TOPS. Your car would overheat severly. I toasted the block in my parents' 88 caravan with a blown head gasket just drivin 3 miles from work to home.
__________________
Marshall
04 Subaru Forester XT Daily!
http://www.wasatchviolins.com
TUNA
marsbike is offline   Reply With Quote
Old 10-11-2004, 12:29 PM   #7
Gerbilo
Gerbilo's Avatar
iTrader Rating: (0)
Send a message via AIM to Gerbilo
Default Re: symptoms of blown head gasket? (marsbike)
On a road trip me and a friend blew the headgasket on his Jeep. We knew it right away, we were just hoping we could make it to a rest stop or something. The temp was in the red the whole time, white smoke was coming out of the tail pipe and under the hood, and it lost all performance. It only took a short while for it to go from "just a lil hot" to completely killing the car.
__________________
92 Harvard Blue Civic EX - Sold
03 Redondo Red Accord EX-V6 - Family ****
05 Shoreline Mist Metallic Civic EX-SE - Family **** II
00 Dark Violet Pearl Integra GS-R - My baby http://images.honda-tech.com/set1/smile/emsmile.gif
My Integra 9005 Conversion HowTo Get Smart! http://images.honda-tech.com/set1/smile/emthup.gif
MWIR - Midwest enthusiasts, check it!
Gerbilo is offline   Reply With Quote
Old 10-11-2004, 12:43 PM   #8
NightRiderS2K
In-N-Out Burger
NightRiderS2K's Avatar
iTrader Rating: (0)
Default Re: (Sack Master)
Quote:
def. what this guy said Click the image to open in full size. Click the image to open in full size.
__________________
|██ █[FS: FS: (2) 255/35/18 Tires & GSR garage sale!]█ ██|
|█ '03 SS S2000: 18x8.5FF||10RR |██| '95 GSR-T RIP: 11/05/07 █|
NightRiderS2K is offline   Reply With Quote
Old 10-11-2004, 01:20 PM   #9
vidanator
vidanator's Avatar
iTrader Rating: (0)
Default Re: (NightRider-gsR)
not to steal ur thread or anything patrick, but now i'm a little concerned, u said ur spark plugs were grayish, mine are brownish not too light and not too dark, just brown, so is there something wrong with my engine?
vidanator is offline   Reply With Quote
Old 10-11-2004, 01:56 PM   #10
psychotic_z
iTrader Rating: (0)
Default Re: (vidanator)
Quote:
No, golden brown plugs are normal.
__________________
DSM 450cc injectors
Uberdata
Slow
Old 10-11-2004, 03:35 PM   #11
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
well yeah, brownish with maybe a little gray... all 4 of my plugs looked normal according to the pics in the back of the Haynes manual. Click the image to open in full size.
Sweet, nothing wrong with my car, gotta love Hondas. Click the image to open in full size.
About that Jeep, it didn't warp the block or heads did it (driving it in the red zone)?
__________________
member #0001
Old 10-12-2004, 08:17 AM   #12
Gerbilo
Gerbilo's Avatar
iTrader Rating: (0)
Default Re: (PatrickGSR94)
Pistons were scorched pretty bad, the 1-2 cylinders(it's an I6) were starved for oil and it got roughed up pretty badly. Ended up just replacing the block/bottom end because there was a spare one laying around.
it was a jeep w/ 130,000 violent miles, it was time lol
__________________
submit to reddit
Tags
92, accord, blown, gasket, head, honda, ht, integra, rust, s2000, smoke, symptom, symptoms, tailpipe, test, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
