Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Register Forgot Password?
Search
Welcome to Honda-Tech!
Welcome to Honda-Tech.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Honda-Tech community today!
submit to reddit
Old 07-14-2004, 06:19 PM   #26
MiraiZ
1998 Acura Integra
My Garage
MiraiZ's Avatar
iTrader Rating: (0)
Default Re: my wastegate stays open at idle :( (Dr Pooface)
Quote:
Originally Posted by Dr Pooface
tial "style"? Maybe that's your problem. My genuine tial stays closed at idle.
I agree...the wategate make a difference between a safe and healthy engine and a dangerous and unstable setup...
don't skimp here!
__________________
1998 Honda Integra Type R Turbo (All JDM) est. 320whp (race car)
1992 Rover Mini Cooper (team car) est. 90whp (sold)
2004 Subaru Forester Cross Sports 2.0 Turbo est. 210 whp (daily car)
MiraiZ is offline   Reply With Quote
Old 07-14-2004, 06:46 PM   #27
pngfolife
1991 Honda Civic
My Garage
pngfolife's Avatar
iTrader Rating: (0)
Default Re: my wastegate stays open at idle :( (MiraiZ)
http://www.atpturbo.com has the valve seat for 38mm Tial wastegates. They are $40. Get one. I was running without one for a couple of months and once I got it, spool up was crazy. I had gotten used to the lag. Spool was so incredible at part throttle, I had to adjust my BOV cuz it was hella leaking at part throttle.
pngfolife is offline   Reply With Quote
Old 07-14-2004, 07:18 PM   #28
egturbo
Garage is empty, add now
iTrader Rating: (0)
Send a message via ICQ to egturbo Send a message via AIM to egturbo
Default Re: my wastegate stays open at idle :( (pngfolife)
^^ do u know what to type down for search i can't find it. and damn $40 is alot Click the image to open in full size.
egturbo is offline   Reply With Quote
Old 07-15-2004, 11:53 AM   #29
egturbo
iTrader Rating: (0)
Default Re: my wastegate stays open at idle :( (egturbo)
ok i've tried opening it. dunno what im lookin at lol. but it does go all the way down. but when i start the car it opens back up. i tried put the tube to vacuum instead of the turbo and still opens. i can't stand the smell of exhaust anymore makin me tired.
Old 07-15-2004, 04:34 PM   #30
egturbo
iTrader Rating: (0)
ok went to super autobacs they dont have that part Click the image to open in full size. went to inlinefour they dont have it. where can i get one? went on that site u guyz gave me dont know what im looking for. sorry im newb.
Old 07-15-2004, 05:00 PM   #31
egturbo
iTrader Rating: (0)
wait where does that o ring go to? between the piston and the wastegate? or between the wastegate and the flange?
Old 07-15-2004, 05:08 PM   #32
DENCIO
DENCIO's Avatar
iTrader Rating: (0)
Send a message via AIM to DENCIO
Quote:
Click the image to open in full size. Click the image to open in full size.
DENCIO is offline   Reply With Quote
Old 07-15-2004, 06:50 PM   #33
egturbo
iTrader Rating: (0)
Default Re: my wastegate stays open at idle :( (hookonboost)
k opened up the wastegate update on page one.
Old 07-15-2004, 09:39 PM   #34
egturbo
iTrader Rating: (0)
Old 07-16-2004, 12:24 AM   #35
Just Checking In
Just Checking In's Avatar
iTrader Rating: (0)
If your exhaust gas is stinking you up so bad you can feel yourself getting tired thats really bad, your getting carbon monoxide poisoning, and theres a very thin line between being tired and and passing the **** out. Take your car to someone that can help you sort out any exhaust leaks or what your stink is from wether it be oil, fuel coolant etc...Getting tired from exhaust is nothing to take lightly. Is your wastegate just venting to atmosphere under your hood? Put a dump tube on it so it leaves the gas under your car. My car stinks really bad too, and gets small white puffs of smoke every now and then but my coolant level stays constant, so its gotta be fuel. Im working on why it smells so bad at idle and cruising, I'll get back to you if I find out. Running 450's on a vafc set @ -40% before 3,500 rpm.
Just Checking In is offline   Reply With Quote
Old 07-16-2004, 12:42 AM   #36
egturbo
iTrader Rating: (0)
Default Re: my wastegate stays open at idle :( (Just Checking In)
Quote:
exactly. thanks for the reply im gettin it just like u. white smoke at idle every now and then. it doesnt have a dump tube my stupid mani makes it hard to put on an elbow. im running 450's with uberdata with basemap. i think imma just sell this wastegate and get a real tial. this one just stays open. weird. yeah if u find out anything let me know. but for now im not gonna drive my car. to scared. i feel like passing out alot of times. not worth it driving. till i get this fixed.
Old 07-16-2004, 02:38 PM   #37
Just Checking In
iTrader Rating: (0)
Np, and you do know without that valve seat you made pointy arrows to in the picture and called an O ring, your wg will remain open right? I highly suggest getting a dump tube made no matter how funky it is, so that the gas can leave under the car, and also make sure your interior air vents are set on recirculation. This helped me quite a bit. I still get the stink out of my tailpipe though, tell me....when you look at your tailpipe, do you see a buildup of wet darkness that when you wipe with a towel makes black smears with neon yellowish wetness around it? Also do you have a cat?
Old 07-16-2004, 03:44 PM   #38
pngfolife
1991 Honda Civic
My Garage
pngfolife's Avatar
iTrader Rating: (0)
Ummmm... ...it looks like you have the valve seat in upsidedown. The bottom of the seat should be flush with the flange. The missing allen should not affect sealing. Those small allens simply hold the valve to the diaphram. You should be fine with three screws.
Old 07-16-2004, 03:55 PM   #39
egturbo
iTrader Rating: (0)
Quote:
sorry but ur wrong. i just put an allen screw in that missing slot and it doesnt leak anymore. when it was missing u would feel air come out of that missing hole when u pump the piston up and down. its fixxed guyz thanks for all ur guyz support and help. Click the image to open in full size. but now its leaking at another place the stupid turbo flange and turbo i need to put a gasket in between
thats gonna be so much work. anyone know the easiest way to install a gasket? imma have to just take off the whole kit and replace that gasket huh?
submit to reddit
Tags
coming, dump, exhaust, gas, idle, leaks, missing, oil, open, partially, screw, smoke, stays, tube, wastegate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Emails & Contact Details
