HASPORT cable to hydro conversion, VS Innovative Cable to Hydro conversion
#76
Re: (alphajesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alphajesse »</TD></TR><TR><TD CLASS="quote">I don't see the point of installing that if the clutch is still ultimately actuated by a cable.</TD></TR></TABLE>
With the right setup you can gain mechanical advantage putting less stress on the cable. That would lessen the chance of stretch and/or breakage.
#77
Re: (1990crxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990crxsir »</TD></TR><TR><TD CLASS="quote">
With the right setup you can gain mechanical advantage putting less stress on the cable. That would lessen the chance of stretch and/or breakage.</TD></TR></TABLE>
which also leads to less stress on your leg! And due to the ease of controlling the clutch release you also lessen the damage you might do to your tranny!!!!!
#78
Re: No2Psi
This was the guy that started off this thread, and his problem was not being able to adjuxt the clutch. Either it was too loose and would slip or it was too tight and he couldn't shift. I have the same problem with my cable-activated Integra LS tranny. There's about 3" of free play in the pedal, then a very stiff pedal (Exedy street clutch) for the last 2". This doesn't seem like a cable stretch problem. I don't see how the clutch can slip with all that free play in the pedal.
#81
Re: (mario_pic)
you bumped up a long dead thread my friend.
who are you even talking to? click his name, look at his last post date. if its somewhat recent, PM him for the answer.
#84
Re: HASPORT cable to hydro conversion, VS Innovative Cable to Hydro conversion
I know this is an Old thread but I thought I would add my two cents for future readers.
I have experience with both conversion kits.
I have a 90 EF hatch with a B18C Integra motor under the hood,
For the first 2 years I used the innovative conversion, after about a year and a half the main bolt in the middle of the adapter broke and I had to custom make one to replace it. The pedal always felt very stiff and seemed to grab at different points randomly. Also, the innovative conversion itself always seemed wobbly and loose, even when i tightened down the main bolt it would still loosen back up.
I got the Hasport conversion and installed it two weeks ago. The hasport assembly is SOLID (does not wiggle around like the innovative did) And the pedal resistance is WAY less than the innovative conversion. I barely have to press the clutch pedal down compared to the resistance I had before.
I havn't had any cable stretching issues as some have mentioned. And overall EXTREMELY pleased with the Hasport conversion.
I wish I had gotten the Hasport conversion to begin with. It is 100% better IMHO.
~Thanks
Mike L (Denver)
~Thanks
Mike L (Denver)
#86
hey guys, this thread is completely screwing me up but I have a crx, 91 si, which I am getting a Hydo B16B soon, but i plan to keep the cable system, and just convert it to work with the hydro tranny, and I plan to get a innovative one but what do I actually need, the actuator hinge, or the actuator conversion itself here are the links what do I need?
http://www.innovativemounts.com/Prod...ductCode=41001
http://www.innovativemounts.com/Prod...ductCode=41000
#87
Best kit available right now no welding no cutting sensors stay intact
http://www.azht.net/forum/showthread.php?t=125275
#88
[QUOTE=DeCoY;42589391]I know this is an Old thread but I thought I would add my two cents for future readers.
~Thanks
Mike L (Denver)[/QUOTED]
Does anybody know if either company has redesigned there product?
this is the first ive ever heard bad things about innovatives things. And i was literly about tho puch the purchase button for the conversion kit when i saw this thread. THANK YOU!!
~Thanks
#89
okay I have figured it out and here is some help for you guys, if you have a car that had a cable transmission and you just bought a hydro transmission you have 2 choices
1. buy slave cylinders, master cylinders, clutch lines, pedal assembly, etc and convert your car to a hydro clutch car or
2. you can get a actuator lever that will technically make your hydro transmission a cable one by removing all the hydro stuff, it is cheaper and easier hope it now makes sense to all of you
but I do have one question if you convert your hydro clutch to a cable one with the innovative or hasport actuator, do you need hydro of cable clutch motor mounts?
#90
#91
I have since gone with the Sonem(Suja1) kit and have had better results after moderately reinforcing the bracket. Pedal effort is still quite firm but not as bad as with the other kits. At least I can actuate the clutch and it engages/disengages properly.
I would have to recommend the Sonem kit but this kit posted by judgeDredd looks promising too.
#92
This kit is still in test marketing, basicly waiting customer feed back. I ve released a small number of these to the public here locally so I can get road test results form others the my self. The bracketery and configuration have been testing for over two years and have been in use for over 30000 miles of real driving simulation. as of now the kit is in perfect standing and no other testing needed. Version 2 is already in effect and is what will be released to the public in a very short time.
pictures and how to's will follow aswell. In car video and clutch actuation silumations to accompany.
#93
#94
How much stuff under the dash has to be removed? I know on the Sonem(Suja1) kit you would loose the the vent and defrost on the drivers side.
#95
The bracketery and configuration have been testing for over two years and have been in use for over 30000 miles of real driving simulation. as of now the kit is in perfect standing and no other testing needed. pictures and how to's will follow aswell. In car video and clutch actuation silumations to accompany.
#96
#97
Pricing can not yet be stated but what i can tell you it will be competitive and will far exceed anyone's expectations.
#98
yes, you would still loose the vent and the tube. This part is intended for off road use. Those also looking for the "tuck" look understand that in most casing loosing things like A/C heater core, blower motor, etc... is common place. The pictures posted on the other website were more of a teaser. Website and E Commerce are still in the building process. When websites up and running all your questions will be answered.
#100
i would wait for the Hush22 kit speaking from experiences with have used the sonem kit myself.
