What can you use to remove a stuck spark plug?
Can you use penetrating fluid, WD40, etc to remove a spark plug that the previous owner jammed in too hard and now won't come out? Or does anyone have any other suggestion for what to use?
Re: What can you use to remove a stuck spark plug? (Campee)
it sounds like it was cross threaded. if so i don't know how to fix it but im sure its very expensive.
Solbros Owns Me
Re: What can you use to remove a stuck spark plug? (FlamencoEsi)
just use a breaker bar...
worst case scenerio you have to pull the head and drill it out
Re: What can you use to remove a stuck spark plug? (Emerika)
Well, it's not frozen... it's just really hard to remove and I wanted to knock it loose w/ something first.. thought I could have used one of the liquids i mentioned earlier. Are those cool to use or no?
I've used a couple drops of 10w/30 to help out a tuff plug.
On a side note if you get one thats stuck, stick a piece of dry ice on the plug, it shrinks the metal in the plug and helps loosen it up.
they make anti-seize stuff to put on your plugs so they dont stick for future reference. hopefully your threads arent screwed up....
pityocamptes
09-10-2015 09:55 PM
91accordex16
06-24-2005 06:13 PM
