Vibration in Steering Wheel at High Speed
Old 11-19-2001, 09:02 PM
New User
gina's Avatar
Default Vibration in Steering Wheel at High Speed
Hey guys.... I was driving my R over the weekend on the highway and noticed at about 80-90mph my steering wheel is shaking and vibrating unusually. Any ideas of what this could be? I am very low on cash and I dont want to take it to the shop if it is something simple. Any ideas? Thanks in advance for your help !!!!
Old 11-19-2001, 09:07 PM
CW_97_ITR's Avatar
Default Re: Vibration in Steering Wheel at High Speed (00 Type R Chick)
Try checking your tire pressures and see if there is anthing stuck inthe tread of your tires (screw, rocks).
Have you hit any pot holes, or anything else hard with the front wheels? I have heard that the ITR front end can come out of alignment real easy.
Also check your tire wear and dents in your rims.
Hope this helps. good luck!
Old 11-19-2001, 09:11 PM
Akira-R's Avatar
Default Re: Vibration in Steering Wheel at High Speed (CW_97_ITR_071)
Your wheels may need to be balanced again.
Check to see if the weights fell off or something.
--reid
Old 11-19-2001, 11:04 PM
New User
tjtruong's Avatar
Default Re: Vibration in Steering Wheel at High Speed (Akira-R)
--reid
Thats the first thing that came to my mind..
try that before anything else....thats most likely the problem.
Old 11-19-2001, 11:13 PM
B2FiNiTY's Avatar
Your tire probably needs to be balanced.
Old 11-19-2001, 11:17 PM
kitkatR's Avatar
Default Re: Vibration in Steering Wheel at High Speed (B2FiNiTY)
That happens to me but vary little vibration and it is around the 135 to 150 range.
Old 11-20-2001, 02:35 AM
arren123's Avatar
It happens to me too when I rotate the back set of tires to the front.. i think I just have a bum tire because I got the wheels rebalanced and they said it was dead on.
Old 11-20-2001, 04:33 AM
ZygSpeed's Avatar
Default Re: Vibration in Steering Wheel at High Speed (arren123)
Other than rebalancing (which is/was) my guess as well -- try taking the wheel off and then carefully (evenly) re-tightening the lug nuts. This helped me last time, since those jack-offs at NTB don't know how to use anything but air tools! HTH /ed
Old 11-20-2001, 04:36 AM
Rather OG
Back in Black's Avatar
If you're car is lowered and the camber isn't adjusted properly, your front tires are more than likely warped towards the inside. If not, my bet is on the need for balancing
W00tn
Honda Civic (2001 - 2005)
10
06-18-2006 03:24 PM
h22pwr
04-12-2006 06:46 AM
canadianSIR-G
11-09-2005 10:27 PM
Nizzy
08-21-2003 07:31 AM
Quick Reply: Vibration in Steering Wheel at High Speed
