Proper OEM lug nut torque specs ?
Also, it as always important to use a torque wrench for putting wheels on car?
or can i just "feel" for the proper torque?
i've heard it's bad to torque way above specs....may warp rotors. of course, below specs can be bad for obvious reasons.
Location: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Re: Proper OEM lug nut torque specs ? (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D »</TD></TR><TR><TD CLASS="quote">about 'yay' much.</TD></TR></TABLE>
yeah, D always uses his vocal chords as a torque wrench. click clock. lol
Re: Proper OEM lug nut torque specs ? (typeruz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeruz »</TD></TR><TR><TD CLASS="quote">i've heard it's bad to torque way above specs....may warp rotors.</TD></TR></TABLE>
i've always wondered about this, but I would've thought that the warping of rotors comes from using different torque amount on all 4/5 lugs as opposed to using a number different 80ftlb.. in other words if you consistently use X ftlb on all lugs you'll be OK.. if that's the case, are torque specs given to save your threads?
Re: Proper OEM lug nut torque specs ? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">You should always use a torque wrench.
you sir, are a retard. many things need an appropriate bolt stretch that should be measured... ie, rod caps, main caps, tranny components... others can be rednecke'd with no issues.
D
D
Re: Proper OEM lug nut torque specs ? (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny »</TD></TR><TR><TD CLASS="quote">Same as the oil drain plug </TD></TR></TABLE>
cool...so ill just put it on like the plug, with my air gun.
thanks craig
thanks craig
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">You should always use a torque wrench.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D »</TD></TR><TR><TD CLASS="quote">you sir, are a retard. many things need an appropriate bolt stretch that should be measured... ie, rod caps, main caps, tranny components... others can be rednecke'd with no issues.</TD></TR></TABLE>
You, sir, are very quick to throw nasty insults around without any provocation. Perhaps you are having a bad day. (Cubs fan, perhaps?)
You also ignore the fact that the question was asked about lug nuts and it would be reasonable for anyone to assume that my response should be taken within this context. However, since you are clearly more interested in attacks than in having a reasonable discussion, I will rephrase my response:
You should always use a torque wrench when tightening wheel lug nuts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">You should always use a torque wrench when tightening wheel lug nuts.
I agree.
I agree.
...and license plate bolts
Darth ModerVader
Re: Proper OEM lug nut torque specs ? (Jason)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason »</TD></TR><TR><TD CLASS="quote">
...and license plate bolts </TD></TR></TABLE>
But then sometimes they don't end up with the screw-heads vertically aligned.
Of course you can just guess, but it is definitely a best practice to use a torque wrench whenever possible. Guessing works fine and dandy until you mess something up.
If you over torque the lugs you can damage the threads and risk the lugs falling off or having to cut a stud because you can't get the lug off. that is why you should use a torque wrench to tighten lugs but as long as you don't go he-man strength and just get them tight with a 4way or however you personally do it you should be good
