2000 civic si in car fuse box diagram, or tell me where this fuse is....
Old 10-02-2003, 08:39 AM
staticchmbr's Avatar
Default 2000 civic si in car fuse box diagram, or tell me where this fuse is....
on my 2000 civic si, the passenger head light blew out on the low beams. i changed the bulb, checked the wires, and it still doesnt work. i need to know where that fuse is, because thats the only thing left that i can think of. i cant find the panel cover with the diagram. i also checked the search over and over. please give a pic of the diagram, or tell me where that fuse is.
Old 10-02-2003, 08:51 AM
Charlie Moua's Avatar
Default Re: 2000 civic si in car fuse box diagram, or tell me where this fuse is.... (staticchmbr)
WELL pull one buy one and check....if you don't have the diagram... should not take more than 3 mins
Old 10-02-2003, 09:20 AM
Phastnphun's Avatar
Default Re: 2000 civic si in car fuse box diagram, or tell me where this fuse is.... (Charlie Moua)
Out by the battery there is a fuse box. Its like a 30amp fuse I think? and if I rember right its the one in the center?
Old 10-02-2003, 10:05 AM
i guess i could just try all the fuses, but there are like 20 of them under there. i will also check the one under the hood, but i dont think its there. wont hurt to check. anyone else have input?
Old 10-02-2003, 10:22 AM
sil
sil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticchmbr &raquo;</TD></TR><TR><TD CLASS="quote">i guess i could just try all the fuses, but there are like 20 of them under there. i will also check the one under the hood, but i dont think its there. wont hurt to check. anyone else have input?</TD></TR></TABLE>
it's not by the battery.. and i'm pretty sure it's a 10amp fuse.. i don't remember which one it is.. but i've basically narrowed it down some more for you..
Old 10-02-2003, 10:42 AM
PupaScoopa's Avatar
Default Re: 2000 civic si in car fuse box diagram, or tell me where this fuse is.... (sil)
Middle row, far right two fuses are for the low beams. The low beams are on a different circuit than the high beams, so your highs should be working right now. If they don't it may be a problem with the harness.
Old 10-02-2003, 10:57 AM
jerseybrandon's Avatar
High/Low Left/Right all independent fuses???
Might want to look elsewhere.
Old 10-02-2003, 12:34 PM
civickidd99's Avatar
Default Re: (jerseybrandon)
pupascoopa got it, check highs and go from there
superturbo11
05-30-2012 07:52 PM
basiceg6
05-05-2009 07:46 AM
integrakid
12-11-2005 05:57 PM
playerzz
11-11-2003 12:22 AM
Quick Reply: 2000 civic si in car fuse box diagram, or tell me where this fuse is....
