Greddy boost gauge???
Old 07-27-2003, 07:53 AM
92TEGsrSC's Avatar
Default Greddy boost gauge???
I was recommended by some friends to get a greddy or apexi boost gauge instead of autometer if I wasn't pinching pennies, so I went ahead and ordered the greddy boost gauge... on the website it's really hard to get a close look at the boost gauge... is my gauge the one everyone receives?... the gauge only goes up to 2.0 and is in kg/cm2 (squared) units... I was expecting lbs/in2. Are all greddy gauges like this??? do any of the greddy boost gauges come in psi units? Also, what is the conversion. how many psi of boost is 0.5 kg/cm2.... 1.0 kg/cm2.... 1.5 or 2.0 kg/cm2? Should I keep this gauge, or send it back? I guess this is probably a newbee question, but I would appreciate any help you guys can give me...
Thanks in Advance,
Zack
Old 07-27-2003, 07:59 AM
Aiyoko Turbo's Avatar
Default Re: Greddy boost gauge??? (92TEGsrSC)
Yes. I believe none of them are in psi. It's cool you know, but when it comes to tuning and looking for advice, it just takes another step to convert it.
I have the AutoMeter Boost gauge and it works really well, showing up to 20 psi of boost and 30 thingies of vaccum.
Old 07-27-2003, 08:03 AM
2lowintegra's Avatar
Default Re: Greddy boost gauge??? (Aiyoko Turbo)
1bar is 14.5psi....
Old 07-27-2003, 08:04 AM
AcuraFreak's Avatar
Here ya go pretty simple enough:
.4Bar (5.8psi), .6Bar (8.7psi), .7Bar (10.2psi), .8Bar (11.6psi) .9Bar (13.1psi), 1.0Bar (14.5psi), 1.1Bar (16.0psi)
Old 07-27-2003, 08:10 AM
92TEGsrSC's Avatar
Thanks a lot guys... I just looked on Apexi's website and it says you can get their Mechanical boost meters are available in PSI and KPA... which are better, mechanical or electronic? Also, does Greddy also offer in PSI and KPA for mechanical? what is your guys opinion on this?
Old 07-27-2003, 08:34 AM
Default Re: (92TEGsrSC)
i use a mechanical, because i heard it was easier to install, but i don't know anything about the electrical, so i guess im lost there.
Old 07-27-2003, 09:46 AM
bluebullet's Avatar
Default Re: Greddy boost gauge??? (2lowintegra)
Actually to get technical 1 bar = atmospheric pressure = 14.7 psi
Old 07-27-2003, 11:25 AM
ek9vboi
Guest
Posts: n/a
is there a BIG difference in what kind gauge company it is? in my opinion, they are all the same, work the same....just different looks. i got carbon fiber autometer gauges and they lookin tyte in tha nite.
Old 07-27-2003, 11:35 AM
vtec.dc2's Avatar
.1bar = 1.422334331psi
its not that bad once you use it.. pressure won't jump all over the place.. readings in bar matches standart wasteage spring setting anyway..
Old 07-27-2003, 11:53 AM
maddog20's Avatar
Greddy boost gauge is not in BAR it is Kg/cm2 1=14.22
Old 07-27-2003, 01:26 PM
Elite Hatch's Avatar
Default Re: Greddy boost gauge??? (maddog20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 &raquo;</TD></TR><TR><TD CLASS="quote">Greddy boost gauge is not in BAR it is Kg/cm2 1=14.22
Same thing bro
Old 07-27-2003, 03:09 PM
maddog20's Avatar
Nope, not that it is big deal but a BAR is 14.7 psi while kg/cm2 is 14.22psi
Old 07-27-2003, 06:16 PM
Default Re: (maddog20)
you make a good point. nearly exactly the same tho I am very suprised that they are indeed not the same
Old 07-27-2003, 06:21 PM
maddog20's Avatar
LOL! sorry not trying to be ****! But every tenth counts especially on stock bottom end KABOOOOM!
Old 07-27-2003, 06:30 PM
vtec.dc2's Avatar
thats a good point.. although i used kg/cm2 which i though was the same as bar..
so its .1 kg/cm2 = 1.422334331 psi
Old 07-27-2003, 06:41 PM
maddog20's Avatar
try this to help you with conversions
goto http://xtronics.com/reference/convert.htm
T3T495GSR
08-20-2003 04:23 PM
ntegls
04-10-2003 10:18 AM
GorData
07-05-2002 02:52 PM
VTC_CiViC
06-01-2002 10:36 PM
Quick Reply: Greddy boost gauge???
