Old 03-25-2015, 09:11 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
Accord 91 Fuse box diagram
Old 05-27-2009, 08:35 AM
Juan_Mitosis's Avatar
Default Accord 91 Fuse box diagram
I have searched,and cannot quite find the diagram for the fusebox of an Accord LX Sedan 91, the fuse box thats inside the car. There are a bunch of blown fuses, previous owner was retarded, and I need the diagram so I can replace with the correct fuses. Thanks in advanced!
Juan_Mitosis is offline
Old 05-27-2009, 12:12 PM
dafang's Avatar
Default Re: Accord 91 Fuse box diagram
Diagram attached, this is for a 92, but should be the same as a 91
dafang is offline
Old 05-27-2009, 12:55 PM
Wow!! Thanks man! Do you also happen to have the fuse box diagram for the one thats under the hood? =D
Old 05-27-2009, 02:30 PM
dafang's Avatar
Under Hood fuses
dafang is offline
Old 05-30-2011, 01:16 AM
vinsanity's Avatar
Icon3 Re: Accord 91 Fuse box diagram
Thank you soooooooooo much. I do hope that it helps me, if not thank you for at least helping. Went tyo the dealer and they waNTED TO CHARGE ME 160.00. THANKS FOR THIS WEBSITE
vinsanity is offline
Old 05-30-2011, 06:59 AM
boat49's Avatar
Exactly what I was looking for too! In my short time on this site I have found alot of information that I couldnt find anywhere else........Great site!!
boat49 is offline
Old 06-25-2011, 02:46 PM
gaby21's Avatar
I Have A 1991 Honda Accord Dx..My Dashboard lights and tailight are out ..I replaced the fuse and it keeps on blowing..I have no clue were to begin to look for the short..can you help me please
gaby21 is offline
Old 06-25-2011, 05:22 PM
dafang's Avatar
I would start by removing all the bulbs, checking that the bulbs are OK, checking the sockets for any sign of damage. checking for any damaged wire at the sockets.
dafang is offline
Old 02-10-2012, 04:21 PM
blk91accord's Avatar
sorry for hijacking the thread but I have a similar problem on a 91accord except mine does not even crank, no dash lights, no headlights, all fuses checked, alternator tested battery is new.
The weird thing is there must be a short somewhere because the battery voltage read 9V a week after it stopped working, I tried to started then the voltage dropped to 2V-3V, but if I disconnect the battery, then the voltage starts climbing up to 6V.
Any ideas?
blk91accord is offline
Old 02-11-2012, 06:39 AM
Lost Again's Avatar
Any ideas?
Take the battery to a parts store and have it tested, based upon your description, be prepared to buy a new battery.....
Lost Again is offline
Bradlyn Jae
06-24-2012 07:20 AM
maineduckhunter
11-14-2008 09:41 AM
garageEF
03-17-2007 04:30 PM
Quick Reply: Accord 91 Fuse box diagram
