2004 Accord ac problems
Old 04-10-2013, 11:08 AM
Bear7285's Avatar
Default 2004 Accord ac problems
Car will blow hot air but no cold?
Old 04-10-2013, 11:24 AM
My Name is Nobody
MSchu's Avatar
Default Re: 2004 Accord ac problems
have you had any service done mate?
they need to check for leaks and charge.
Old 04-10-2013, 03:24 PM
Bear7285's Avatar
Have not I will have them check it:
Old 04-10-2013, 05:24 PM
Racer02gtstang's Avatar
The the ac on pop the hood and see if both fans are running. If not it probably has a leak or such. If they are then it could be electrical. Check ac relay by tapping it and see if compressor kicks on
Old 04-11-2013, 08:02 AM
Bear7285's Avatar
thank you I will try that
Old 04-17-2013, 10:39 AM
Bear7285's Avatar
Ended up being a bad a/c compressor 900 later
Old 05-18-2013, 05:03 PM
Accordman1's Avatar
Sorry to hear that. Where did you take it to? If you had never checked the freon level since you got the car, it could be the problem. The AC system works mostly in the summer and hardly working in the winter time except when you ran the windshield defroster. It usually leak freon in the winter because of dry seals or connectors. You need to run the AC at least once a month when the weather is warm enough to keep it lubricated. When the freon level is low, it will cycle the compressor on and off constantly and is likely the cause of the compressor seized and died. Same go for your home AC too so check that freon level once a year. However, I had similar problem on my older Accord and it turned out to be the relay to control the compressor that failed. It was $180 to get it replaced, a lot better than $900 compressor.
E30LS1
Honda Civic (2001 - 2005)
07-09-2014 09:40 AM
CheeseKT
06-16-2005 11:13 PM
vietnogi
05-24-2005 08:01 AM
cfortman
08-05-2004 09:08 PM
Quick Reply: 2004 Accord ac problems
