Special bolts for ignition switch –Why?
Old 02-04-2013, 07:16 AM
cctgene's Avatar
Default Special bolts for ignition switch –Why?
I’m in the process of replacing the ignition switch on my son’s 96 Accord and it struck me odd that it requires special twist off bolts to hold the switch to the steering column. Anybody know why it was engineered that way?
Old 02-04-2013, 07:19 AM
92 civic ex 4dr's Avatar
Default Re: Special bolts for ignition switch –Why?
help prevent theft.
Old 02-04-2013, 07:31 AM
He knows where you live!
TheMuffinMan's Avatar
The switch itself doesn't have those bolts - the steering column has them though. Is that what you're referring to? The switch has 3 ~6mm bolts. The shear-head bolts on the column aren't necessary to replace. You can work around them and/or replace them with regular ones if you need to.
Old 02-04-2013, 08:00 AM
cctgene's Avatar
The shear bolts on the column was what I was asking about. The switch itself works fine the problem is that the key is stuck. I don't know if the key lock is available by itself, but none of the local auto store carry it, but they all seem to have the combined switch and key lock assembly together in stock. Anyway, I was just curious about the shear bolts. The theft thing makes sense to me, so that’s probably the rational for the special bolts.
Thanks
Old 02-04-2013, 08:15 AM
Gotcha, yeah I figured you were going for those. And sorry - I figured you were attempting to replace just the switch which is held on by those three bolts which tends to go bad over time. If you've got a stuck key I think you're going to have to get those guys off.
You can buy replacements ones at the dealer, or I'd recommend just getting some Grade 8 or so bolts from the auto parts place.
Old 02-04-2013, 02:04 PM
zsiya's Avatar
Have you tried removing the key assembly? On the 4th gen, there is a spring pin on the side of the lock cylinder that removes the lock. May be able to remove/replace just that part.
Old 02-04-2013, 08:33 PM
holmesnmanny's Avatar
Thanks
I'm almost certain that every parts store has em. It's called Lock Cylinder assembly. What you need to do is to put the key in and turn it to 0 position. Then you will need to use something like a paperclip to push in the button on the inner part of the assembly then the lock cylinder will slide out. You will see the button inside the hole. Just push it in and pull on the key and the lock cylinder will slide out. The lock cylinder assembly will come with the lock cylinder and two keys.
madcrx69
02-14-2011 02:56 AM
heeltoeNdro
17
05-13-2008 03:06 PM
jaghouse
06-15-2007 12:28 PM
lone
12-28-2004 07:40 PM
wuhungsixxx
04-10-2002 08:21 PM
Quick Reply: Special bolts for ignition switch –Why?
