Honda S2000 Honda S2000
S2000+NOS+Spoon ecu= WOW
Old 04-01-2003, 06:09 PM
Captain Save-a-Hoe's Avatar
Default S2000+NOS+Spoon ecu= WOW
311hp and 243ft lbs of torque. Ill post the charts up tomorrow.
The ecu made the fuel curve ultra linear after the initial kick of the Nitrous. The higher the rpms went the richer the fuel mixture was. There was enough fuel for more nos, but the stock clutch wasn't gonna hold up.
The installer of the Nitrous kit(hes a guru) was baffled by how the ecu compensated for the nitrous. He looked like this . He couldnt believe it, he thought the dyno was malfunctioning and even checked the plugs.
Fuel was around 11:1 between 6-9k rpms. He believes he can get 370hp out of the car.
Spoon
[Modified by Cartek-Tuning, 11:52 PM 4/4/2003]
Old 04-01-2003, 06:23 PM
Aquafina's Avatar
Default Re: S2000+NOS+Spoon ecu= WOW (Cartek-Tuning)
Must have been a big shot. How much?
Old 04-01-2003, 08:11 PM
Default Re: S2000+NOS+Spoon ecu= WOW (SuperStreetRX7)
The guy that set the car up didnt even want to disclose the amount . He said he'll make more power after we put a clutch on the s2000.
Old 04-01-2003, 09:02 PM
PROFILES2000's Avatar
can you maybe post up the dyno sheet and o2 reading? im curious to how he kept an 11. the hole time
Old 04-02-2003, 11:08 AM
Blue-Civic-Hybrid's Avatar
I would like to see these charts too....Hmmm..Spoon ECU...
Old 04-02-2003, 12:43 PM
illi Adik's Avatar
Thats hot.
Old 04-02-2003, 07:27 PM
TypeR 01 886's Avatar
Default Re: S2000+NOS+Spoon ecu= WOW (Jackson4Door)
g00d l0rd
Old 04-02-2003, 08:23 PM
Evo s2000's Avatar
Default Re: S2000+NOS+Spoon ecu= WOW (TypeR 01 886)
what is he using for fule set up? only the spoon ecu? That's a whole a lot of NOS
Old 04-03-2003, 04:48 AM
djsbon's Avatar
great number (311, good band)
great results using great techniques.
Old 04-03-2003, 11:18 AM
gsracer170's Avatar
Default Re: S2000+NOS+Spoon ecu= WOW (djsbon)
wow, i always figured that the Spoon ecu was no good for forced induction, because it advances timing... i'm also
Old 04-03-2003, 06:16 PM
m777erlin's Avatar
Post the charts!!!
Old 04-03-2003, 07:38 PM
Default Re: S2000+NOS+Spoon ecu= WOW (m777erlin)
Post the charts!!!
Here it is, I couldn't scan it but I took a pic of it. The big jump in a/f will be ironed out with tuning, but it shows the stability of the fuel afterwards. It gets more rich as the rpm's climb.
[Modified by Cartek-Tuning, 11:45 PM 4/3/2003]
Old 04-08-2003, 02:36 PM
BoM
BoM's Avatar
was it a wet kit?
Old 04-11-2003, 11:25 AM
gsracer170's Avatar
Default Re: S2000+NOS+Spoon ecu= WOW (BoM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoM &raquo;</TD></TR><TR><TD CLASS="quote">was it a wet kit? </TD></TR></TABLE>
has to be is he's running more than a 50 shot
j0keefe21
09-07-2009 09:39 PM
95greenlude
05-02-2007 02:02 PM
freakie
05-16-2002 10:38 PM
xxplosif1
04-21-2002 07:06 AM
Quick Reply: S2000+NOS+Spoon ecu= WOW
