help with oil control orifice!
Old 07-13-2012, 10:46 AM
GreatwhiteDC2's Avatar
Default help with oil control orifice!
I have a B18c1 engine. I know there is an oil control orifice on the block, which I know I have on, but I'm worried about if there is one in the center of the head because Im not sure if its there or not? Ive been driving my car for about 2 months and just came across info on it today which is friday the 13th!! Is it possible to be driving this long w/o that orifice on the head? What exactly would happen if I didn't have it?? Help me out HT!
Old 07-13-2012, 10:53 AM
EJ8_Man's Avatar
Default Re: help with oil control orifice!
You mean the O-Ring was not placed in the orifice and what will the damage be?
Are you talking about this?
Old 07-13-2012, 12:23 PM
Yes sir that is what Im asking about. Is it just an o ring there or is there something underneath it as well? I had it hot tanked and Im not sure if its there or not when I installed it. What are the damages? Oil starvation in the head? Should this be an immediate fix?
Old 07-13-2012, 12:29 PM
EJ8_Man's Avatar
Yes it's just an O-ring. Yes fix it. Your cylinder head is fine, this probably feeds the LMA.
Old 07-13-2012, 12:47 PM
Oh good. Appreciate the help bud.
Btw, do you know a way to install this o ring w/o taking off the cam rail, caps and my timing belt?
Old 07-13-2012, 01:01 PM
EJ8_Man's Avatar
You'll have to pull off the LMA and the cap for those particular lobes. You don't need to take out the cams or Timing belt
Old 07-17-2012, 03:02 AM
Solster's Avatar
Sorry to say you have to pull the 24 of the 28 cam cap bolts out of the cam lobe oiling rail but the only cap you have to pull is the middle one
Old 07-19-2014, 06:31 AM
Britney Hopper's Avatar
Need help does my 1999 honda accord have the oil control oirface? Just had the head redone fixing to put it on and run in to that proplem someone told me there was one need help asap thanks
Old 07-19-2014, 07:18 AM
EJ8_Man's Avatar
Search online and download a manual for your accord and check. This thread is pretty old... My guess is it does need the o-ring
DAdemon93
04-10-2015 06:19 PM
Lamchop0000
11-02-2012 02:34 AM
h22powered
01-07-2004 03:51 PM
Quick Reply: help with oil control orifice!
