ek sleeper... top mount, back door IC, and A/C....
Old 09-05-2011, 07:56 AM
draggbody's Avatar
Default ek sleeper... top mount, back door IC, and A/C.... and now awd...
this is project that we have worked on for about 5 months now... the idea was to build a reliable 400hp car that looked and funtioned like it was oem... a true sleeper...
chassis... full energy suspension throughout and a little prothane thrown in there where ES "complete kit" fell short... tokico whites and 1.25" springs, i didnt want the car to be slammed out for a couple of reasons, poor geometry, poor ride quailty and remember it needs to look stock on the outside... staying w/ a mild drop, i was able to keep a decently thick tire on it, 205-55-15's proxes4s on a set of SI's... these fill the wheelwell nice and should give me a good ride... i also have a set of MT 225-50-15s on two more SI's... custom traction bar setup as well new balljoints, tierods, manual rack, and brakes...
exterior... nothing special, the car was wrecked when i bought it, so some frontend paint is coming, aside from that, everything fits under the stock bumper...
interior... i didnt want any visible gauges, so i put a double din head unit in and used a backup camera to monitor the gauges that are mounted in the gutted out glove box... the cruise control is also stuffed in there... this is probably my favorite part, the gauges, not the cruise control... lol
so now for the meat and potatos... we started w/ fully balanced GSR block, eagle rods and 9:1 CP pistons... a ported b16 head w/ skunk2 valve springs and retainers, a S2 intake manifold ported to fit an omni power 70mm throttle body, along w/ 750cc injectors and an AEM fuel rail and FPR... we converted the fuel system to -6 trick flow fuel lines... the turbo is a precision 6031, tial wastegate and greddy BOV all recirculating, just so that it keeps it quiet... we had to custom build a back door intercooler so we could keep the windshield washer bottle .... 2.5" piping was used... a top mount sch10 manifold as well as full 3" stainless, mandrel bent exhaust w/ a magnaflow resonator and full size muffler round out the exhaust side of things... everything will be tuned w/ s300 as well as a full wire tuck... we are using a GSR trans w/ lsd and carbon coated synchro's along w/ a stage 3 competition clutch.... stock axle shafts for now...
now for some pics...
this is how it looked the day i bought it, it was fixed that weekend and off to inspection...
here is a shot of the radio... the second is the box they are mounted in, the camera mounts in the foreground...
this shows the new bumper support, this is the same size as the " styrofoam" support, i needed room for the intercooler, but didnt want to lose the bumper... you can also see the relocated battery...
a few shots of the engine bay... the downpipe is wrapped in a sleeve to help w/ under hood temps... as well as everything is ceramic coated...
we wrapped the harness in this braided loom... its a pain to work w/, but well worth it...
Old 09-05-2011, 07:58 AM
Retired Moderator
EsotericImage's Avatar
Default Re: ek sleeper... top mount, back door IC, and A/C....
Looks great! in4moar
Old 09-05-2011, 08:01 AM
I serve phở for my babies
ohsnapzafingcu's Avatar
nice build!
Old 09-05-2011, 08:12 AM
Speed_1's Avatar
What A/C condensor are you using? Have any pictures of around the turbo and the a/c line to the condensor.
Old 09-05-2011, 08:18 AM
draggbody's Avatar
stock condenser and lines... lines bent a little and the condenser is moved under the top of the radiator support... the bottom half of the stock radiator support is cut of to make room for the ac and the radiator, the crossmember for the traction bars doubles as the new lower radiator support... i'll get some pics of that for you...
Old 09-05-2011, 11:31 AM
draggbody's Avatar
this is the catch can setup... i wanted the engine bay to be as clean as possible, so we made a bracket that bolted it to the rear lower side of the intake manifold, bungs are welded to the valve cover and a baffle was built to keep oil from slinging into the lines... all of the catch can lines are trickflow -10 and a k&n filter tops it off... the lower lines drain back into the lower part of the block, thus, keeping the system maintenence free...
Old 09-05-2011, 11:41 AM
chuwi_pty's Avatar
looking good!!!!
Old 09-09-2011, 07:13 PM
draggbody's Avatar
well she's alive!!! after basically building a wiring harness from scratch, it fired right up... i shortened an obdII harness and converted it to obdI... pin by pin, added a connector between the engine harness and the body harness so that the engine harness could be removed... i managed to put the IAC pin in the wrong spot, and had the power wire installed to ground instead of key power and i have problems w/ the ELD... i know i can turn the ELD off in the s300, what are the down sides to that, i am going to try to figure out where i screwed up, but i am still interested in the proper function as well as the downside to just turning it off...
Old 09-09-2011, 07:17 PM
effin's Avatar
o wow what a great setup amazinggg x 1000
Old 09-09-2011, 08:22 PM
LightningTeg's Avatar
The gauge thing is clever but You could probably had just done a tunerview
Old 09-09-2011, 10:22 PM
draggbody's Avatar
this only looks at parameters set by the ecm... would work as a boost gauge, but wouldnt give me a/f or oil pressure... these are nice units though...
Old 09-10-2011, 07:17 AM
92frostwhtdb2's Avatar
I like the catch can.
Old 09-10-2011, 10:08 AM
kyledupreez's Avatar
that is awesome. any more updated pics?
very cool i must say. sleepers are the best.
Old 09-10-2011, 10:25 AM
Builda'Teg_92's Avatar
I don't think anything is wrong with removing the ELD....somebody else will chime in.
Good job so far.
Old 09-10-2011, 08:15 PM
draggbody's Avatar
here are some shots of the traction bar setup... the tabs that bolt into the frame rails are laser cut from 1/4" mild steel and the crossmember is .120 wall DOM... the heims are 1/2" and the bars are 1" .120 wall... the control arm tabs bolt into the bolt that sandwiches the LCA together...
a couple of shots of the intercooler and downpipe...
and todays progress... hood stripped and primed, bumper repaired and some dings fixed in the fenders...
you can see here how the bumper fits up w/ the IC behind it, everything in tact with a little grinding on the back side of the "grill" in the bumper... obviously the IC is blacked out now...
Old 09-11-2011, 08:15 AM
ShanghaiOC's Avatar
Keep up the good work. Nice to see all that hard work has paid off.
Old 09-11-2011, 02:56 PM
guessohw's Avatar
Looks good. That catch can is a smart idea. Marketing time!! Keep us updated and more pics!
Old 09-11-2011, 07:01 PM
turbo-2nr's Avatar
the a/f can be read by the ecu and should be for data logging purposes, and you can also put a 5v oil sensor imputed in to the ecu so both can be seen on the tuner view
Old 09-11-2011, 07:15 PM
Retired Moderator
look who it is! hey buddy!
OP: keep up the good work! lookin good
Old 09-12-2011, 06:34 AM
draggbody's Avatar
thats an interesting thought... maybe next time i guess... thanks for the info...
Old 09-14-2011, 08:30 PM
draggbody's Avatar
the front end is painted and i couldn't be more satisfied... i long blocked and reprimed everything, water sanded and took it to my friend that owns a bodyshop and let them spray it in there booth... i am most satisfied w/ the headlights... these things were practically garbage... the driverside had been sprayed w/ what appeared to be rattlecan clear and i cleaned it off w/ a razor blade... then i took 400 grit on the DA to it and finished up w/ 600 grit wet sanding... we just sprayed regular dupont clear on it and they look new... not just good, brand new, and they are genuine honda parts as is everything on the front end that was used to fix the wreck...
line locks in the rear and a little more wiring and i'll be ready to drive this thing!!! it will happen by the weekend...
Old 09-15-2011, 12:21 PM
jz98ctr's Avatar
Looks good...def liking the sleeper status...especially the wire sheathing and tuck...clean
If you're keeping AC...the area behind/around the AC condensr HAS to be tight...
what with the turbo...manifold...wastegate...BOV...condensor all withing a 1 foot area.
It's hard to tell from the pics that you have posted up. Got any good ones showing clearances in that area?
Old 09-15-2011, 06:53 PM
draggbody's Avatar
its like 10lbs of **** in a 5lb bag... lol... the consensor was able to go under the rad support and cocked sideways because of the new lower radiator support/ traction bar mount. you can see here that the condensor sits WAY out front, i had to heat the headlight housing to dimple it in where the mounting bolt goes and also remove the mounting tab for the bumper off of the bumper as well as the radiator support...
Old 09-16-2011, 03:55 AM
Fc_v8's Avatar
Nice project, I see that you have your oil return line coverd with something to keep the heat away i asume. What is it? because im looking to do the same and dont know what to buy. thanks in advance!
Old 09-16-2011, 08:36 AM
draggbody's Avatar
here is the insulation i used... bottom of the page on the right... it 1" od... mcmaster-carr is the ****... there are lots of other wraps in there catlog, i love that place!!!
http://www.mcmaster.com/#catalog/117/803/=e378f3
Quick Reply: ek sleeper... top mount, back door IC, and A/C....
