Edelbrock Performer x VS Victor x
Old 02-29-2012, 01:21 PM
Broertje's Avatar
Default Edelbrock Performer x VS Victor x
Which one do ya'll recommend? I heard victor is more ofr the mid range, and performer for top end. And not to mention the fact its $100 cheaper.
Which one is preferred and why?
Old 02-29-2012, 01:29 PM
thegatekeeper14's Avatar
Default Re: Edelbrock Performer x VS Victor x
I run a fully ported and polished victor x from Renown Performance. How ever i would like to see the performer x and what it can do. Heck contact Renown and have them port one for you.
Also your gonna wanna share your set up so we can accurately suggest a quality performing manifold for you.
Old 02-29-2012, 02:12 PM
Broertje's Avatar
Well I havent put a solid setup together, but its gonna be Boosted, +/- 300 WHP.
Old 02-29-2012, 02:26 PM
lsturbo33's Avatar
For 300 just use a stock manifold.
Old 02-29-2012, 02:44 PM
joe b's Avatar
Anything less than 500whp and its a waste !!! Trust me i know !! Stock will be more than sufficient for up 450 whp .
Old 02-29-2012, 03:05 PM
m3tech95's Avatar
Longer runners=lower rpm power increase
Larger Plenum=higer rpm power increase
If your only revving to stock or 8,200 rpm, go with the Performer X = Power-band 4500-8200
"The Performer X intake manifolds for Acura and Honda's are engineered for street/strip applications where peak torque and horsepower gains are realized between 4500-8200 RPM. The larger-than-stock plenum volume and 9" runner length are tuned for producing peak power at high RPM."
If your going to be revving to 10,000 rpm go with the Victor X = Power-band 7000-10,000
"Optimized for maximum power from 7,000 to 10,000 RPM, the Victor X manifold is designed for turbo and all-motor applications. Engineered for high performance, this manifold has four additional bosses for nitrous or added fuel injectors"
This is regardless of if your turbo or N/A that's what range they were designed for. Hope this clears up some confusion about the difference in these two manifolds.
Old 02-29-2012, 05:05 PM
DarryCar's Avatar
I have the JG Eddlebrock intake mani on my turbo application. Does anyone know if this is the Vector X or Performer X?
Old 02-29-2012, 05:13 PM
DraginX's Avatar
It is the victor x.
Old 02-29-2012, 06:15 PM
Turbo-LS's Avatar
Op aftermarket manifold will increase over stock, perform will be suitable for stock redline and the power your looking for. Victor is for larger turbo and power goals
Old 03-01-2012, 02:26 AM
Broertje's Avatar
Ok thanks everyone, these manifolds cost like $300-400. How much gain will i get over stock AVG? Are we talking like minimal gains due to 300whp or
Old 03-01-2012, 03:50 AM
LS AzZkIkr's Avatar
Under 500hp = skunk2, AEBS, stock
Over 500hp = victorX, Magnus, golden eagle
Just my $.02
Old 03-01-2012, 04:59 AM
Turbo-LS's Avatar
300whp is 300whp. if might give you a little more low end and mid range power but stock will work fine for 300
Old 03-01-2012, 05:52 AM
Broertje's Avatar
Ok thanks
Old 03-05-2012, 06:09 PM
DarryCar's Avatar
Originally Posted by DraginX
It is the victor x.
Thanks. All it says on it is JG Edlebrock on it. I have had it for a while and just forgot which one I had. It worked great when I had 384whp and it still flows great now at 515whp. Hoping it will still flow good at 600+. Good mani for the price.
Old 08-16-2017, 01:13 AM
Knox839's Avatar
Is there someone who knows victor x manifold capacity ? I want to compare it with skunk2 ultra street manifold which is 1.8 liter and if you use spacer it will be 2.3 liter.
LS AzZkIkr
03-26-2010 06:42 PM
Panda Eg6
04-23-2008 12:06 PM
kyorishin
40
05-18-2006 09:47 PM
90teg
05-02-2006 02:14 PM
blues2k3
Honda S2000
33
05-12-2005 06:37 PM
Quick Reply: Edelbrock Performer x VS Victor x
