99 accord coupe front end vibration
Old 02-21-2012, 04:26 PM
1991EX's Avatar
Default 99 accord coupe front end vibration
This is my third accord and am having difficulty fixing my steering wheel vibration. Miles are 111000, new tires, fresh rotation and balance. I am getting a vibration at about 70 MPH, under throttle, letting off etc. I thought for sure it was a tire / balance issue but am now stumped.
Is there anything on these 6th gens that is a common issue in the front end? It does have an aftermarket axle on the left side. It is a one owner that has never been wrecked.
Next is putting it on a lift to check the bearings etc. Just looking for obvious issues to check first.
BTW, any good sources for hub/bearing assemblies? Might as well change them at 111000 miles....
Old 02-22-2012, 06:01 PM
ricebike's Avatar
Default Re: 99 accord coupe front end vibration
did it vibrate before the new tires/ rotation/ balance job?
and you rotate the tires front-to-back to make sure that the tire/balance issue is ruled out?
ya, putting it on a lift or up in the driveway to check all bushings/joints/tie rods/bearings is a good check as well...
Old 02-24-2012, 05:02 AM
1991EX's Avatar
Thanks. So far I have balanced / rotated and even tried another set of wheels/tires from another accord. After putting it on the lift I noticed that the replaced (newer) axle shaft has minor play (rotational) in it. Everything else is tight.
My plan right now is to install new brakes / rotors, then tranny mount, then the left shaft. If that does not fix it I will live with a 70+ mph vibration. I have done a complete tune-up to include a new dizzy to fix an internal leak. The engine runs very smooth, shifts great, so I am running out of things to relate to a vibration.
thanks for the reply!
Alpaca
06-06-2019 04:40 PM
Paul Shelton
03-29-2018 05:45 PM
RichieHHix62
02-05-2018 12:55 PM
ukrainianstyle
10-09-2008 06:18 AM
Ed 341
08-14-2006 04:02 PM
Quick Reply: 99 accord coupe front end vibration
