Where is the PCV valve in civic 98 lx?
Old 01-31-2012, 11:56 AM
dishjuarez's Avatar
Default Where is the PCV valve in civic 98 lx?
1998 Honda Civic LX, 195k
I want to clean the air induction system but I have a question, where is the PCV valve?, What are the points to be checked in the system?
thanks
Old 01-31-2012, 12:10 PM
Steezer's Avatar
Default Re: Where is the PCV valve in civic 98 lx?
thanks
if im not mistaked the pvc is on the fuel rail
Old 01-31-2012, 12:17 PM
dishjuarez's Avatar
Thanks, can give someone pict's?
or can tellme where search, thanks?
Old 01-31-2012, 12:27 PM
alphalanos's Avatar
PCV valve is under the intake manifold. Easier to see from under the car. Connected to a black metal box looking thing.
Old 01-31-2012, 01:37 PM
Wrona's Avatar
u are very mistaken on the fuel rail? what car are u talking about.. not a honda i've worked on has ever had a pcv valve on the rail
Its underneath ur intake manifold best way to get to it is from the bottom
here's the DIY i used when i changed mine for the first time
http://www.diymyhonda.com/civic/gara...acement-d16y7/
Old 01-31-2012, 05:31 PM
dishjuarez's Avatar
Simply added to my favorites... thanks
Old 01-31-2012, 05:46 PM
Master Detailer
98civdx's Avatar
You are mistaken.
As said the PCV is a black box under the IM, just above the oil filter.
Do it at the same as you change the oil, it makes it a lot easier without the filter there.
But, you may try from up top, that is how I did mine. The crappy y7 IM will really make you mad doing this, so get ready to swear.....
UrbanDiplomat
03-17-2013 08:27 PM
Turbochargedcivic
08-02-2006 08:04 AM
civicbuny
01-04-2005 03:23 PM
Marcos
04-12-2003 06:02 AM
Quick Reply: Where is the PCV valve in civic 98 lx?
