popping noise from front end 98 civic
Old 01-31-2012, 08:26 AM
hawksftball2007's Avatar
Default popping noise from front end 98 civic
NEW TO HONDA-TECH...... so every once and a while i will get this loud popping creaking sound when going over speed bumps and sharp turns or combination in school parking lot(main time i hear it). I am not sure whether it is a dry ball joint (needs grease) or the inner tie rod . the noise is from passenger side. i ordered new ball joint boots for the camber kit(newer) to see if it fixes the problem. but how can i test to pinpoint the noise. i have shaken wheel sideways up down all around and no movement. which is why i am leaning toward dry ball joint (boot is torn). but any help is appreciated Thanks.
hawksftball2007 is offline
Old 01-31-2012, 08:47 AM
cdn ek9's Avatar
Default Re: popping noise from front end 98 civic
Check your lower and upper balljoint. Mine made that noise when the lower balljoint worn.
cdn ek9 is offline
Old 02-02-2012, 01:52 PM
I checked and lower ball joint was fine, but wat i figured out was when i replaced upper ball joint boot. the coilover bushing where it attaches to car, had a popping noise so i tightened the bolt and nut up, and no more popping noise. Thanks
Old 02-02-2012, 02:17 PM
pityocamptes's Avatar
So what did you tighten? My vehicle does not pop, but it does make this irritating creaking noise when going over bumps. I was starting to think its the rubber mounts that go on either side of the springs. I know the rear makes the same noise. I have checked the ball joints and they are fine. Thanks!
pityocamptes is offline
Old 02-03-2012, 02:03 PM
the bolt that attaches the camber kit to the car. it was loose. so i put a bit of locktite on it and tightened it down....creaking sounds like from springs. but try and tighten the bolt and nut down for the front upper control arm.
Old 05-05-2015, 10:50 AM
ali954's Avatar
Revival from the dead to pass along info.
My brother's 97 civic was making a loud pop mostly when he would back out of driveways with the wheel cut right. Turned out to be a loose bolt on the upper control arm where it bolts to the body. He was able to replicate the noise at a stand still and I could see and hear it. Problem solved.
ali954 is offline
Old 05-05-2015, 08:24 PM
Former User's Avatar
^Good info.
I'll lock this old thread now.
Former User is offline
SiRkid
12
06-09-2005 12:05 PM
rudeman85
11-04-2004 01:19 PM
B-B-K
10-04-2004 12:00 PM
chrisw
03-26-2004 08:07 AM
Quick Reply: popping noise from front end 98 civic
