OBD2 port not working
Old 10-19-2011, 10:20 PM
Eddy562's Avatar
Default OBD2 port not working
I put a b16a jdm engine into my 97 civic ex. I want to get it bar'dm but my obd port isn't working. Can it be that that I have a jdm ecu? (p2t).
That is the only thing holding me back....
any help is appreciated! ( and yes i am a noob, trying to learn!)
Old 10-20-2011, 06:15 AM
b16a2ek's Avatar
Default Re: OBD2 port not working
what year is the b16? i have a b16 from the 2000 si and am running a jdm p2t with no problems but i did need a jumper harness to go from obd2a to obd2b due to the wiring harness for the car being different
Old 10-20-2011, 06:18 AM
The Grumpiest
grumblemarc's Avatar
Originally Posted by Eddy562
...a b16a jdm engine...
This is your problem.
Old 10-20-2011, 07:05 AM
apexi_rsx's Avatar
I have a jdm ecu? (p2t).... this is the problem that ecu dont support the diagnostics port
Old 10-20-2011, 01:53 PM
Kista20's Avatar
I'd say you hit the nail right on the head there. You will need to run a usdm ecu.
Old 10-20-2011, 10:14 PM
Eddy562's Avatar
the engine is from 99/2000 si
how much was the harness and what kind?
Old 10-20-2011, 10:15 PM
Eddy562's Avatar
Will my d16 ecu work on the b16? it is a usdm p2p?
Thanks again
Old 10-20-2011, 10:24 PM
Eddy562's Avatar
Old 10-21-2011, 04:00 AM
The Grumpiest
Nope. Did you not research this before you did the swap?
Old 10-21-2011, 07:20 AM
dpetro1's Avatar
The car should run. Just not properly. Probably won't pass BAR that way
Old 10-21-2011, 11:28 PM
Eddy562's Avatar
So should I try and get the ecu of the b16a2? what would be the difference?
Old 10-21-2011, 11:29 PM
Eddy562's Avatar
What do you recommend for me to be able to pass?
Thanks
Old 10-22-2011, 06:13 AM
apexi_rsx's Avatar
get a usdm b16 ecu from a 99-00 si or a b16 del sol
Old 10-22-2011, 06:51 AM
Eddy562's Avatar
Alright, just out of curiosity, how would it change by switching ecu's, performance wise, should I still use the jdm ecu after I get everything bar'd?
Old 10-22-2011, 07:03 AM
apexi_rsx's Avatar
switching ecu's will not do much both usdm b16 makes similar power to the jdm b16. the jdm ecu redline is 8200 vs usdm 8000 and vtec engagement for the jdm is 5800 and usdm is 5600. just little ecu tweaks are the differance. the jdm motor just has a slight bump in compression over the usdm b16. 10:6 vs 10:2
Old 10-22-2011, 07:20 AM
jayWknight's Avatar
Jdm ecus do not communicate with usdm scan tools that is the reason behind your issue. Also since you are trying to bar your car, try to find a 96-97 p30 from a 96-97 del sol dohc vtec. The bar techs wont take kindly to jumper harnesses and the wrong ecu.
Old 10-22-2011, 03:47 PM
Eddy562's Avatar
Thanks everybody! I will try to buy everything on my next check and let you guys know how it went
WeB
03-09-2010 11:50 AM
EcRzFinesT
15
10-10-2009 10:25 AM
toyotaninja
19
09-15-2009 02:17 AM
ep3drvr
13
04-17-2009 09:41 PM
Ehron
11-04-2002 12:13 PM
Quick Reply: OBD2 port not working
