94 civic cx no fuel no spark help please
I am having problems with my 94 civic cx the fuel pump is not working and I'm not getting any spark it will turn over fine I have already replaced the main relay and have also put in a new ecu thought it was just a fuel problem but checked for spark today and had none is this a bad ground somewhere maybe? Any input will help
Re: 94 civic cx no fuel no spark help please
Already have and nothing even cleaned the ground on the thermostat and made sure ithad a good connection still nothing
I haven't tested them but the fuses were good even replaced with new and nothing. I will test them tommorrowto see if they have power going to them
When you turn the key from off to ON(II), does the CEL turn on and then off after 2 seconds? Or does it stay on steady?
That is what I thought but wasn't completely sure I will test the fuses to see if I'm getting anything if they are not how do I fix it?
I will post the results tommorrow butim almost positive that it will not have any power cause I've eleminated almost everything else it could be
If the one of the fuses does not get voltage, then (5) there's probably a bad wire between the ignition switch or hood fuse box and the fuse.
Obviously, some methodical electrical testing is needed to precisely pinpoint the problem.
wtfisvtec??
36
08-16-2023 07:31 AM
punkracer
04-02-2005 07:32 AM
ZColeon
11-13-2001 03:08 PM
