Hard to shift!!
Hard to shift!!
Im looking for a new car at the moment and found a good deal on a 94 acura integra rs. Car needs some paint but runs good the only thing is when I shift into ANY gear it takes alot of effort(I MEAN LOTTTSS). The seller says he hasnt driven the car since march and that it may be because of that..but I highly doubt it. Im thinking it could possibly be fluid or something???
Re: Hard to shift!!
b4 even doing that have the car off and stopped and try shifting without anything
if your feeling lazy you can always stop on a flat street put it in gear and try and push it (not recommended but....)
Re: Hard to shift!!
havent tried jacking it up and spinning the wheels but while the car if off its the same..no grinding or noise but it feels similar to pushing a stick back and forth while stuck in super thick mud..if you can imagine that lol
Re: Hard to shift!!
First thing first, if it's shifting hard then it could possibly low on fluids. Second, check the slave cylinder. That could be the reason why. Third and last is the clutch may have seen it's end of life if it's shifting hard or won't even shift at all when the car is turned on.
Re: Hard to shift!!
I had the same problem in my 98. I checked the clutch master cylinder yesterday and it was low. I added some fluid and the shifting got better. I think that my clutch master and slave cylinder need to be replaced soon. Does anyone know if the Integra master and slave cylinders are the same as a Civic?
Re: Hard to shift!!
lay down and look at the fire wall inside the cabin right where the clutch rod goes threw the firewall, see if it is damp or wet. If so the master cylinder is bad. Also checking fluid level will tell you that something is wrong if it is low. Wont get low unless there is a leak.
Re: Hard to shift!!
Re: Hard to shift!!
The reason why it won't work is because...... "Granny shifting, not double clutching like you should!!!!"
Not double clutching like you should
Re: Hard to shift!!
I replaced my clutch master and slave cylinders and the shifting became much easier at lower RPMs. However, shifting is still difficult at higher RPMs. I am not ready to change my clutch because it doesn't slip or feel bad. Could worn motor and transmission mounts make shifting more difficult? Mine mounts are just about done.
Re: Hard to shift!!
i did the same thing..it was my clutch, it was my clutch, it was so warn out the springs were falling out and pieces were broke off..replaced it and it shifts like butter now..
13BT
14
05-29-2010 09:02 PM
