Catalytic converter
Old 06-13-2011, 04:22 PM
justdoinme23's Avatar
Default Catalytic converter
would a code be thrown for a obd II b16a2 bad cat...or could i have a bad cat, with no code be throw...having acceleration pro's..just checking....maybe its clogged but would i throw a code? there are no codes presently, thx
Old 06-13-2011, 05:04 PM
redm3turbo's Avatar
Default Re: Catalytic converter
mine tossed a code...60 I believe.
ran perfectly, got great mpg...no noise...nada.
Threw a code and couldnt get rid of it except changing it...
Old 06-13-2011, 05:07 PM
95EG2's Avatar
take the cat off if ur acceleration goes away clogged cat if it still there it another problem
Old 06-14-2011, 08:47 PM
NotAJDMFanBoy's Avatar
There's a mod involving two spark plug defoulers you can do to trick the ECU into getting an acceptable reading from the secondary sensor. Take first defouler, drill through it. screw the 02 sensor into that, then screw those into the 2nd defouler, and that into the exhaust.
Old 06-15-2011, 06:37 AM
jumby's Avatar
actually here is a link. need to do this to mine so I have it bookmarked. everything is running fine so I just want to shut the light off. don't want to miss any other codes that might show up.
http://www.civicforums.com/forums/22...on-w-pics.html
Old 06-15-2011, 06:43 AM
Former User's Avatar
A bad cat will almost always throw code P0420.
scott_turner
04-30-2011 04:14 PM
tcbbandman
01-25-2011 01:17 PM
spray_bombed
07-22-2007 04:14 PM
LillDragun
07-06-2002 08:04 PM
lopey
03-10-2002 12:28 AM
Quick Reply: Catalytic converter
