Oil Pump Gasket
Old 06-05-2011, 10:56 AM
Nshouse0003's Avatar
Icon2 Oil Pump Gasket
Got a 95 Honda Accord EX V6 2.7L and i've got an oil leak coming from between my oil filter housing and my oil pump. I've come to the conclusion it's the oil pump gasket (#31 below) and i was just wondering if anyone on here has ever replaced this gasket before and if so how hard is it to do? I'd like some pointers and suggestions if possible as there isn't very much room to work in that area at all and i'd like to have a plan before i go tackling this thing. Thanks for any input.
Old 06-06-2011, 05:09 PM
Jdm1117's Avatar
Default Re: Oil Pump Gasket
Having the exact same leak..hopefully someone will chime in..
Old 06-08-2011, 12:19 PM
nus_dogg's Avatar
It doesn't look too bad, but maybe the clearance between the chasis and engine may be a tight spot to work with.
Old 06-09-2011, 11:29 AM
supracord's Avatar
#31 is likely an o-ring. This is the back of the oil pump from my F22a1. I was puzzled, and even posted a thread about the lack of gaskets Honda uses on oil components, especially where the surfaces mate. The entire perimeter of this oil pump does not have a gasket! You just use Hondabond (RTV). So, when you remove the oil filter bracket to replace the o-ring, I'd recommend cleaning the surfaces where they mate (acetone worked great for me) and applying a bead of Hondabond. Unfortunately, I already had the engine pulled when I did all of this, so I can't be much help in the "how hard will it be?" department. Good luck!
90AccordSi
01-06-2012 04:28 PM
EGR95
05-26-2009 06:47 PM
Tzarinque
09-19-2008 09:59 PM
JLefevers
07-09-2006 02:14 AM
GruvyTune
07-05-2002 08:57 AM
Quick Reply: Oil Pump Gasket
