How to fix broken speedometer.
I have a 1994 honda civic and when i drive sometimes the speedometer needle does not move or sometimes it goes to outrageous numbers like i could be going 30 mph n it goes all the way to 60 or even 100 what could be the problem?
Re: How to fix broken speedometer.
I have this same problem...I do not think it is the speed sensor. I have replaced that, and it still does it. Im thinking its in the wiring behind the cluster?? It is a DX chassis/body, but has a EX cluster. The car runs like normal, vtec still kicks. So any more info on this would be greatly appreciated!
THANKS!
THANKS!
some times the circuit board goes bad on the rear of the gauge. you'll see this board once you remove the gauge from the cluster housing.
when i bought my car the speedo would randomly work, i changed out the board from a junk yard gauge, and started working right away.
venom363
05-08-2007 11:48 AM
