OBD2 scanner cannot communicate with my car. Please Help!
Old 02-11-2011, 11:57 AM
JR_98spec-0315's Avatar
Default OBD2 scanner cannot communicate with my car. Please Help!
Hi I did a bit of searching and still haven't been able to resolve my issue. I am unable to get my car to communicate with any scanners. I have tried three and all three did not connect. I don't have any check engine lights, but finally got a note for emissions, so in order to pass I will have to get this resolved So any help would be greatly appreciated!
It is a 1998 Integra Type R, the vehicle came with a JDM ecu which was part #
37820-P73-013, will the car only communicate with a USDM ecu?
I've checked the fuse panels under the dash and hood, and they all seem to check out. My only other idea would be to test the obd2 scan port to see if it is getting voltage, does anybody have a diagram of which pins i should test? Thanks in advance!
Old 02-11-2011, 12:18 PM
MilFhunter001's Avatar
Default Re: OBD2 scanner cannot communicate with my car. Please Help!
That's weird, i'm running on obd 1 and that for sure wont scan at all.
Old 02-11-2011, 12:21 PM
well its got a JDM front so wiring could be a major concern, I'm just hoping that isn't the case, and if by chance anybody would have any experience with this issue . .
Old 02-11-2011, 12:41 PM
racebum's Avatar
Originally Posted by JR_98spec-0315
37820-P73-013, !
is the reason why you're scan tool isn't working
i can't believe this post has went this far without someone telling you what the problem is
jdm ecu's don't use the US scan protocol
Old 02-11-2011, 01:24 PM
I like to party
2LEM1's Avatar
^This
I'm also shocked.
Old 02-11-2011, 01:29 PM
Thanks for the help, I was worried that was the case, but glad its not a wiring issue as of yet then. Now here's to hoping I can find one at a reasonable price ...
Old 02-11-2011, 01:38 PM
kevinthefawker's Avatar
pretty much the jdm ecus run a obd1 interface but has the ecu plugs like the us obd2s, just pop in a us obd2 ecu and you can scan away
Old 02-11-2011, 01:46 PM
that makes sense, well at least my fuses are in check then. Any idea on what I'm looking to pay for a USDM ecu? Should it be about the same as a JDM one? I'm hoping i could trade the 003 I have, if at all possible?
Old 02-11-2011, 07:50 PM
racebum's Avatar
what year is your car? like the frame? p73-a02 and a03 are expensive. i sold one of each a year or two ago for $150 and now they are fetching that to $250 pretty easy. a02 is the 97 ecu and a03 is the 98. if you run a a03 in a 96-97 car you'll get a gas tank code
Old 02-12-2011, 05:39 AM
well its a 98 so I would be looking for the a03, which I am not too sure if I will be able to find in time or at price. .
Do you think it would be possible to use a GSR ecu for a 98 in order to pass emissions, or will that cause more trouble then it would help?
thanks again for all the help!
Old 02-12-2011, 08:53 AM
it would be some trouble because the gsr ecu would look for the iab and some other stuff the type R doesnt have hence throwing a code. maybe look for somebody that would loan it out for you if you get them a deposit and return it when you are done.
Old 02-12-2011, 11:51 AM
racebum's Avatar
the iab's won't throw a code, think of the skunk manifold on the gsr. the evap however will. do you still have the factory evap system in place? the gsr ecu would work if you switched it in the parking lot, passed emissions then went back to the itr ecu....might work anyway no idea what tailpipe emissions would do if they both scan and test. i know a lot of states just use the scan tool and send you on the way if there are no codes
Old 02-12-2011, 12:05 PM
wego5typer#431's Avatar
There is a usdm 98 type r ecu currently on craigslist(San Francisco bay area).
He is asking $220
Old 02-12-2011, 12:30 PM
racebum's Avatar
which means he wants $200, that's a pretty fair deal
Old 02-12-2011, 01:58 PM
Im in IL here and they only hook up to the scanner as far as I know. Also I am pretty sure all the evap equipment is still in place
Thanks for the heads up on the CL seller emailed him, hopefully he wont think I'm a Nigerian scammer!
Old 02-12-2011, 06:49 PM
DC5yo's Avatar
I wanna say that JDM cars don't even have diagnostic ports. . . but I could be wrong.
Old 02-13-2011, 04:08 PM
well its a USDM R and has a diagnostic port, I touched base with the guy off CL he wants to do 250 shipped through ebay. I'll probably end up going with that, just so i can get emissions taken care of and done with. Thanks for all the help, very appreciated!!
Old 02-13-2011, 09:09 PM
racebum's Avatar
still not a bad deal shipped and verified with ebay and paypal, the most you would save if you waited around is probably $75, totally not worth waiting a year plus for a few bucks. the other thing is if this is a03 that's the exact ecu you need for your car. not a year off, not close but exact
you did switch the oil pumps and hook up your cfs sensor when you did the engine swap right? if you didn't you'll have a code for the cfs
Old 02-14-2011, 06:11 PM
Bizarre's Avatar
Just a suggestion, if you're only using this ECU for emissions and to not drive the car very much why not just pick up an LS non vtec ecu? I would assume that they are going to be much cheaper than a "Type R" ecu. Also I'm pretty sure you wont have any codes regardless because the ls ecu has less sensors than the ITR one. I know this worked fine for my OBD1 B16 swap when I was diagnosing some ecu problems. I drove around on an LS computer for 2 days with no codes. Obviously vtec and such wont work but it's not like it matters from an emissions stand point.
Old 02-24-2011, 07:27 PM
received my USDM ecu and passed emissions 5 minutes after i hooked it up! thanks for all the help!
Old 06-17-2019, 12:48 AM
Pjcricket's Avatar
Hello,
I have failed emissions on my 99 Integra Type R as well, would you mind sharing what the issue actually was that you found out thanks to the scanner?
Thanks a lot.
Old 06-17-2019, 04:53 PM
I shoot brides
yoshi234's Avatar
Originally Posted by Pjcricket
Hello,
Thanks a lot.
I'd recommend starting a new thread w/ your concerns. This thread is over 8 years old and the original poster hasn't been on HT since 2013.
y shi - who thinks 234 will need a smog check this winter
Old 06-18-2019, 01:30 AM
Pjcricket's Avatar
Hi Yoshi234,
Thank you for the advice, I will open a new thread to explain the issues I am facing.
Thanks.
dc4teggiehatch
09-10-2021 02:55 PM
killakalipoph
02-01-2010 04:48 AM
rollintegra
01-06-2009 12:40 PM
herbalist
16
10-09-2005 06:52 PM
Quick Reply: OBD2 scanner cannot communicate with my car. Please Help!
