Where the hell is the MES connector??????
Old 03-01-2003, 02:31 PM
New User
lahight's Avatar
Default Where the hell is the MES connector??????
Can someone please put up a pic or give a detailed explanation of where exactly the mes connector is on a 95 EX? Please, there so many conflicting descriptions. It is definitely a two prong connector correct? Please help.
Old 03-01-2003, 04:14 PM
GimpyAccord's Avatar
Default Re: Where the hell is the MES connector?????? (lahight)
If you're reffering to the service jumper (to check codes, set timing etc) on most 5th gens I've seen that is below the glove box usually in a little blue holder (unless you've had it out before and just left it hanging). If thats not what you're looking for please clarify and I'll try to help!!
[Modified by GimpyAccord, 5:15 PM 3/1/2003]
Old 03-01-2003, 04:32 PM
carolinaACCORD's Avatar
Default Re: Where the hell is the MES connector?????? (GimpyAccord)
yes, gimpy is right. its under the glovebox, in another connector. just look up in there and pull it out. its only a 2 wire plug.
Old 03-01-2003, 08:29 PM
Chiovnidca's Avatar
No, he's after the memory erase signal (MES) connector. It's used for eraseing SRS codes. It's on the left side of the dash near the fuse box. It will have either two gray wires, or one black wire and one white wire.
Old 03-01-2003, 10:10 PM
Default Re: Where the hell is the MES connector?????? (Chiovnidca)
Funky!!!! and now I know.
no SRS equiped accord unfortunatly in my garage... or fortunatly that is.
Old 03-01-2003, 11:29 PM
New User
lahight's Avatar
anyone have any pics or a more detailed description, i have been breaking my damn neck under there and i cant find it
Old 03-03-2003, 01:13 AM
New User
lahight's Avatar
please, anyone?
Old 03-04-2003, 01:06 PM
New User
lahight's Avatar
bump
Old 03-04-2003, 01:48 PM
Default Re: Where the hell is the MES connector?????? (D16Chiovnidca)
wow, i never knew that. i always thought of that as the MIL service check connector.
Old 03-04-2003, 10:09 PM
New User
lahight's Avatar
I know someone knows the answer and has time to waste....
Old 03-05-2003, 10:37 AM
subnet's Avatar
Here you go...
MES 90-97 Accord at right bottom edge of dash.
[img]c:\mes.jpg[/img]
Here's the URL http://alflash.narod.ru/honda.htm
[Modified by subnet, 2:40 PM 3/5/2003]
[Modified by subnet, 9:01 PM 3/5/2003]
Old 03-06-2003, 01:02 AM
New User
lahight's Avatar
Default Re: Where the hell is the MES connector?????? (subnet)
Thanks!
94CoupeEJ1
14
01-01-2013 01:59 AM
codybuRr
14
02-07-2011 05:26 PM
crist488
Lighting
01-08-2010 09:55 AM
jdmland
09-09-2007 08:48 AM
delsoldude
Audio / Security / Video
11-14-2004 09:44 AM
Quick Reply: Where the hell is the MES connector??????
