Does exhaust leak affect performance?
Guest
Posts: n/a
I have an Apex'i Dunk cat back. Would it affect my performance if I had multiple exhaust leaks. There is some kind of rattling around the stock header/downpipe around 3000rpm because it was custom done to fit my jdm h22 header to the h23 downpipe. Also, when I installed my catback, I never had the gaskets with it. TIA.
heezy
heezy
Re: Does exhaust leak affect performance? (ophdeheezy)
YES
your going to suffer from pressure lost and it does make some performance difference
also may make it even louder if the gasket isnt here or not sized right
[Modified by KTeller8, 11:11 PM 2/26/2003]
how big is the difference? is it noticeable? where CAN i get gaskets from? should i go through apex to get new exhaust gaskets or should i just go through a muffler shop or something?
what size is it?
i might be able to get you one...
email me mkteller8@aol.com
it depends on the size of the hole in your exhaust. My brother had a leak in his exhaust on his civic and the car was a dog, i'm pretty sure it has something to do with back pressure. So he got it fixed and his power is restored.
yea i got the saem problem i have a leak where the A pipe meets the B pipe on my dc 421 header. what should i do muffler shop, or call dc
Re: Does exhaust leak affect performance? (h22jedi)
alot easier to deal with
dc might waste time or might not do anything. never know with the big boys
to the other guy. see if your stock gasket fits up. worth a try
Re: Does exhaust leak affect performance? (KTeller8)
yes, back pressure is a very needed thing with a n/a car, i dunno if it would be bad to the point of making it a "dog". but you might notice some difference, plus it sounds like shyt
YoungKadafi
03-12-2007 12:08 PM
