93 Accord - Starter relay?
Before I actually go looking. I'm having a problem with my car not starting. Heres what it's doing. BTW I had a 91 Accord and it did the same thing... I fixed it by soldering some joints on a relay but I forget which relay and where it was. The problem is (seems as when the car is hot) when I turn the ignition on (not turning the engine over) all the check lights come on, including the engine light. When this engine light goes off theirs this clicking noise as if it were a switch. If I hear this clicking noise the car will start. When the engine light goes off and I DON'T hear the clicking noise the car will still turn over but it will never start. I have to turn the ignition on and off, on and off over and over until I hear the clicking noise for it to start. Which relay is this and where?
Re: 93 Accord - Starter relay?
Ok I've done some searching and found that it is called the main relay that I was looking for. I was going to do the solder it yourself deal.. but all the solder points look fine... no broken solder points? Could it still be the main relay? Or should I look for another solution?
russ_512
02-12-2011 05:34 PM
