Is there issues if one tire has a lower speed rating then my other 3?
Old 09-11-2010, 01:54 PM
tnywy's Avatar
Icon2 Is there issues if one tire has a lower speed rating then my other 3?
Hey all,
Please help me out if you could - I need to replace a tire on my 2007 Honda Accord EX, and my tires currently have v rated tires. But there's a nail in one of my tires and I'll need to replace it. Would it be disadvantageous to have one of my tires have a H-rated tire and different from the rest? I don't drive any more than 80 mph usually, and I only drive it to work and occasional short trips to restaurants/markets. Help please?
Old 09-11-2010, 02:39 PM
H-T Order of Merit
nsxtasy's Avatar
Default Re: Is there issues if one tire has a lower speed rating then my other 3?
Yes and no.
It shouldn't be a problem to use tires with different speed ratings because of their speed rating, as long as you're not exceeding the speed for the lowest speed rating you have - in this case, 130 mph for the H rating.
However, it's a bad idea to use tires that have significantly different performance characteristics from each other. For example, if you have three grand touring all-season tires, it's a bad idea to mix them with one (or more) maximum performance summer tires, because they will behave differently from each other, and this different behavior can change depending on the conditions. It can not only degrade your car's handling, but also make it unpredictable. That's why it's best to use four tires of the same make and model where possible, and otherwise to mix them only with tires in the same performance category.
Old 09-11-2010, 04:16 PM
tnywy's Avatar
Thanks nsxtasy. I thought that'd be the case. I'll pay the extra to get the same performance tire then
Old 09-12-2010, 05:16 PM
CountDracura's Avatar
No tire or vehicle manufacturer will ever recommend mixing speed ratings. While you wont run in to many issues with top speed stability as nsxtasy has fore mentioned, the sidewall construction does change from speed rating to speed rating. If you are forced to mix speed ratings, it is recommended to place the higher speed rated tire on the rear so as not to induce over steer on turns in inclement weather.
Old 09-15-2010, 08:11 AM
Cooper The Tire Rack's Avatar
Both nsxtasy and CountDracura (nice name, btw) have good points. In a pinch, I am not against selling a pair of H-rated tires if the same tire isn't available in V-rate. But that's as low a step I am willing to take. Going from V to T or lower may cause remarkable differences in handling, lateral roll, oversteer, etc.
Makdaddynuge
09-18-2005 10:04 AM
classciv
08-27-2005 05:45 PM
Kelvin96GSR
01-19-2003 03:31 PM
Fuster_Cluck
12-18-2002 05:31 AM
O1 Coupe
04-06-2002 03:44 PM
Quick Reply: Is there issues if one tire has a lower speed rating then my other 3?
