Civic wont start... has fuel, spark.... help??!!
Old 09-08-2010, 09:40 PM
ryan_1014's Avatar
Default Civic wont start... has fuel, spark.... help??!!
Bought a 93 civic lx, bone stock. Had a burnt valve but didnt start when I bought it.
Put a new head on there, timing is dead on, has spark, all injectors are working, fuel pump etc.
no check engine lights, but after trying to start a loud noise is coming from the IACV, im going to try to replace it in the morning but is there anything else that I am missing? All the grounds are good, all 3. all fuses are good. let me know what you think
Old 09-09-2010, 12:31 AM
ryan_1014's Avatar
Default Re: Civic wont start... has fuel, spark.... help??!!
Bump
Old 09-09-2010, 04:43 AM
one6delsol's Avatar
Check compression
Old 09-09-2010, 05:02 AM
Former User's Avatar
Originally Posted by one6delsol
Check compression
^This
And also make sure the plug wires are installed in the correct firing order on the distributor cap.
Old 09-09-2010, 11:51 AM
ryan_1014's Avatar
just did a compression test cylinder 1-4 is (right to left) is 0 40 90 120
the block looked good when I took the head off so im going to recheck timing tonight or maybe the head is warped
Old 09-09-2010, 12:00 PM
ED94LIFE's Avatar
wow dude that sucks
Old 09-09-2010, 09:09 PM
ryan_1014's Avatar
Originally Posted by ED94LIFE
wow dude that sucks
thanks for the feedback stud
Old 09-09-2010, 09:18 PM
phaphon's Avatar
that really sucks did you put the head gasket on correct? if you did a leakdown test you can know whats wrong instead of tearing it down and not knowing where its leaking
Old 09-10-2010, 09:28 PM
USDM sI's Avatar
the same thing happened to my y8/z6 it was a warped head... and do you know how or why the valve went out?
Old 09-10-2010, 10:52 PM
ryan_1014's Avatar
no I bought the car like that, the new head i got was supposed to be good so i guess my next step is take the head to a shop and get it machiened and put another head gasket on it
Old 09-11-2010, 10:02 AM
USDM sI's Avatar
well when you pull it i would highly suggest a leak test with water or oil to see if there is possibly bent valves if its warped you would most likely be gettin oil or antifreeze in the combustion chamber or oil in antifreeze or vise versa
Buddah763
04-02-2012 12:59 AM
D16SiHatch
14
03-09-2012 04:17 PM
Since 1983
11-15-2009 10:24 PM
93civicd16z
02-22-2006 10:10 AM
ericlee303
04-28-2004 03:31 PM
Quick Reply: Civic wont start... has fuel, spark.... help??!!
