GETTING HOT WHILE IDLING
Old 08-14-2010, 10:10 AM
jmacc8's Avatar
Default GETTING HOT WHILE IDLING
I have a 2001 honda civic that continues to get hot when i am sitting and idling for more then 3 minutes or so. Then when I rev the motor or start to drive down the road the temperature will return to normal. I replaced the thermostat but it still has the same problem, although since I replaced the thermostat it seems to not get hot as fast as it used to. I am thinking maybe I got a defective thermostat or possibly the water pump is out. Just wondering if anyone else has encountered a similar problem.
Thanks
Old 08-14-2010, 03:15 PM
Pothole987's Avatar
Default Re: GETTING HOT WHILE IDLING
Any Cels? is your fan working?
Old 08-14-2010, 04:30 PM
Hollywood_Cal's Avatar
water pump,fans,head gasket, temperature sensor,radiator flush or more who knows..
Old 08-14-2010, 06:45 PM
jdmfreak1992's Avatar
Did try burping your rad? Is the fan coming on, if not check the relay?
Old 08-19-2010, 03:33 PM
AutoXer's Avatar
Usually when the car gets hot when sitting, and cools off when driving, it's a fan issue.
Check if it turns on when sitting and getting hot. If not, there's your problem. I had the fuse go on mine once.
Old 08-19-2010, 03:38 PM
ballisticej1's Avatar
Check fan(s) if they're good then its a head gasket.
Old 08-19-2010, 04:54 PM
theineffable's Avatar
did you change your coolant recently? try burping the air out?
i would say water pump but the OEM water pump has metal fins so i don't think there's a problem w/ broken fins...
Old 08-19-2010, 05:21 PM
CRX Si69's Avatar
your thermostat isnt opening.
Old 08-20-2010, 11:52 AM
2002-dxsedan's Avatar
i've got an '02 d17a1, same problem, just needed to top up coolant cause i've got a leaky head gasket. i'm getting oil in my coolant res but have'nt seen any coolant in my oil
cgeorge
08-03-2015 08:44 AM
Boostn B20
48
10-18-2008 08:08 PM
kg4h2l0
10-23-2004 12:30 PM
Nocturnal
02-22-2004 08:48 AM
4505
10-12-2003 05:28 PM
Quick Reply: GETTING HOT WHILE IDLING
