transmission flush.
Old 08-06-2010, 09:34 PM
joe_accord23's Avatar
Default transmission flush.
i have a 5spd gearbox transmission on my accord. my question is how do i change the fluid? n wut type of fluid to use? wuld royal purple fluid word? on my manual it says it uses motor oil in the transmission help me!
Old 08-07-2010, 12:44 PM
holmesnmanny's Avatar
Default Re: transmission flush.
The holes are visible when you take off the front right wheel. The filler bolt is a 17mm bolt that is just above and to the left of the drain bolt which is just a 3/8 drive bolt. I bought a plastic oil holding funnel and tube thing at Walmart in the automotive section for a few bucks that I used to fill up my transmission. You fill up a plastic piece that you can sit in the engine bay and then unlock the locking piece and it'll drain the oil through the tube into the fitting that you sit inside the transmission.
Old 08-07-2010, 06:21 PM
thnx so its specifically for the transmission?...sounds good, and wut type of oil do i use? motor oil? royal purple trans? lemme kno plz
Old 08-07-2010, 10:40 PM
Need to know exactly what kind of car you have, I forgot to ask in my first reply.
Old 08-07-2010, 10:49 PM
There's a website for a local parts shop that gives good specs for most cars.
http://www.alliedautostores.com/Cata...logSubCat.aspx
Just put in your car and year and click on View Specifications at the top right.
Old 08-07-2010, 11:07 PM
bseriescrxsi's Avatar
ive been using gear oil in my 5 spd trans...cant remember the verocity though....
Old 08-08-2010, 01:56 PM
nus_dogg's Avatar
You can go with Amsoil GM Synchromesh or just go with Honda MTF.
Old 08-09-2010, 04:37 PM
thnx alot u guys, i love this forum!
aznromeo4u
02-24-2015 02:52 PM
platanodom
08-08-2007 05:10 PM
GsrTurboCRX88
19
11-21-2006 06:12 PM
shai x boi racer
01-25-2005 06:45 PM
dcrbin22
09-15-2004 10:38 AM
Quick Reply: transmission flush.
