Classic Hondas All Pre-1988 Hondas.
1988 civic dx fuel pump issues
Old 06-20-2010, 06:56 PM
rzecca's Avatar
Default 1988 civic dx fuel pump issues
I have a 1988 civic dx 4 door sedan, 1.5L, I recently have been having trouble with the fuel pump? I figured it was bad as I was getting no fuel and the car would'nt start, will run with Gummout!,. I went ahead and replaced it(the fuel pump),... it still does not seem to pump fuel! I checked the old one with 12 volts and it works! Rats! 201$ out the window! The sevice manual says to check the main relay, located under dash, next to the fuse panel. There is a series of connecting terminals together and providing 12 volts to other terminals in a peticular sequence, it check out good, I'm only getting about 6 volts at the fuel pump/sending unit plug (access under rear seat)? Could my ECU be bad? I'm scratching my head on this one. any advise would be greatly apreciated!!
Thanks,
Old 06-21-2010, 06:11 PM
Gabe87CRX's Avatar
Default Re: 1988 civic dx fuel pump issues
Check the fuse in the fuse box labeled ALTERNATOR / SOLENOID, just had this problem...
Ginpaul
Honda Civic (2001 - 2005)
04-26-2018 06:02 AM
1.6si
01-18-2018 11:59 AM
fordboy15
12
06-07-2013 02:56 PM
rollercosta123
08-07-2005 09:22 PM
b16acrxer
11-13-2003 07:21 PM
Quick Reply: 1988 civic dx fuel pump issues
