Base Tune for LS Turbo (T3/T4, 8psi, DSM Blue Injectors)
Old 01-07-2010, 09:59 AM
MrDomino's Avatar
Default Base Tune for LS Turbo (T3/T4, 8psi, DSM Blue Injectors)
I also posted this on PGMFI.org and am getting some help but it's much less active than HT so I figured I'd post here too.
So I'm pretty sure I grenaded the existing tune in my car and I need to start from scratch to try and get it running again. (I'm going to be using Crome)
I need a base map for an Integra LS with a P06 ECU. The car has a T3/T4 Ebay turbo (It's held up for 3 years with no issues) with DSM Blue Top injectors and runs at 8psi. I'm just going to AFR tune it and leave the ignition somewhat conservative. I know Xenocron has quite a few basemaps but I didn't see anything that was too close so I figured one of you guys might have something laying around that I might be able to use.
After doing some more searching, I missed that Xenocron does in fact have 2 that are somewhat close.
B18b, 450cc injectors, SC34 Turbo, 7psi tuned, timing untouched...bleh
http://www.xenocron.com/bins/index.p...rome/B-Series&
b18b1 T3 super60 .48 hotside 7PSi tune, 11.3 in boost, 12.5-12 before boost, 14.70 everywhere else, Needs a little touch up in boost portion, .75 degreee retard per Lb. timing untouched
Which do you think would be best to start with?
This is really my first time messing with this stuff so a lot of it is brand new to me. I'm kind of nervous about messing with the ignition timing but I can handle adjusting the fuel map.
Old 01-07-2010, 12:37 PM
MrDomino's Avatar
Default Re: Base Tune for LS Turbo (T3/T4, 8psi, DSM Blue Injectors)
My biggest thing is trying to figure out all of the fuel stuff. I'm thinking of using the second map to start. It says that the timing was retarded 0.75 degree per lb of boost. I may up this to 1.00 degree to be safe but when I opened it in Crome the option is not selected.
Also under the fuel tools it says the engine size is 1.6L? Shouldn't it be 1797cc?
Old 01-07-2010, 12:51 PM
dpetro1's Avatar
what tuning software are you using? do you have the hardware to burn chips if needed or an emulator?
Old 01-07-2010, 01:21 PM
MrDomino's Avatar
I have both an Ostrich and a Burn 2 and a bunch of chips.
Old 01-08-2010, 04:43 AM
dpetro1's Avatar
i think you should just make your own basemap and then tweak some of the fuel if needed. xenocron has an awesome write-up http://www.xenocron.com/install/CromeGuide.htm
then get it to a tuner for a full tune
Old 01-08-2010, 09:49 AM
MrDomino's Avatar
I'm going to do all of the Fuel Tuning myself this next week hopefully and then do the ignition in a few months (I'm leaving everything kind of conservative).
Quick question about target AFRs. I know I want 12.0:1 whenever in boost and 14.7:1 whenever I'm idling. What about in between?
Attached in my basemap that I'm going to be using.
Old 01-10-2010, 09:31 AM
MrDomino's Avatar
How does this look for a target lambda map? I don't know how to convert to AFR so it's in terms of Lambda.
Old 01-12-2010, 07:33 AM
HAMOTORSPORTS's Avatar
The map was simply created using a b16/ p30 base. The basemap is most likely already setup for the 1.8l in the fuel trim adjustments, so I wouldn't suggest changing anything here. Your best bet is to pull about 1 deg. timing away across the entire map and then just tune your a/f.
Old 07-15-2010, 07:02 PM
bLu92bUbbLe's Avatar
id luv to do this myself....lookin at that chart gives me a headache....
Old 07-20-2010, 07:03 AM
MrDomino's Avatar
Well I figured out how to do everything just by reading forums so you can figure it out that way too.
Stopsign32v
11-12-2010 09:22 PM
esurf
03-19-2009 07:32 PM
moncrease
03-15-2008 09:49 AM
the.hamburglar
11-13-2005 09:34 PM
egg
02-15-2003 11:29 AM
Quick Reply: Base Tune for LS Turbo (T3/T4, 8psi, DSM Blue Injectors)
