putting ac into a 98 ek coupe gsr swap
Old 12-13-2009, 05:13 PM
GSR936's Avatar
Default putting ac into a 98 ek coupe gsr swap
what do i need to put ac into a 98 civic ek coupe that has a gsr swap ?
Old 12-13-2009, 05:16 PM
Anon51's Avatar
Default Re: putting ac into a 98 ek coupe gsr swap
do you have your original a/c lines? no lines? evaporator? condenser? dryer? compressor?
Old 12-13-2009, 05:18 PM
GSR936's Avatar
car has lines but no ac compressor or condenser
Old 12-13-2009, 05:42 PM
GSR936's Avatar
ttt
Old 12-13-2009, 06:06 PM
Anon51's Avatar
do you still have the gsr a/c bracket bolted on? if not go grab a vtec delsol a/c bracket or its much cheaper counter part the crv b20 a/c bracket. and find a 96-98 d series a/c compressor. unless you wanna use a gsr a/c compressor in which case a gsr bracket and compressor and lines is what you want.
Old 12-13-2009, 06:24 PM
GSR936's Avatar
OK i found a b20 ac bracket for 30 bucks. can i use a 97 auto d series ac comperssor?
GSR936's Avatar
and condenser from a 97 auto?
Old 12-13-2009, 07:00 PM
Anon51's Avatar
yea you just need teh d series compressor lines now that go from the evaporator to the compressor and condensor.
Old 12-14-2009, 06:06 AM
GSR936's Avatar
alright just making sure the ac compressor and condensor were from a 97 civic auto were the same.
Old 12-14-2009, 06:19 AM
318 Curves, 11 miles
Vindicator9000's Avatar
Yes. Everything is D-series except the bracket which should be B20.
On mine, I retained the entire D-series A/C system with the B20 bracket. The D series compressor should bolt up to the B20 bracket and everything will line up like OEM. This is because, if you've ever seen a CRV, it uses a D-series compressor on a B-series engine.
Old 12-14-2009, 06:31 AM
GSR936's Avatar
yes thats good. found a bracket and i got a donor 97 ek auto will all ac lines and stuff
Old 05-07-2010, 08:39 PM
extremeEK00's Avatar
hey where did u find that ac bracket from a b20?
Old 05-07-2010, 08:41 PM
im thinking about putting a gsr swap into a 00 civic coupe and thought i needed the gsr ac bracket but read this and seen i need a b20 bracket?? is that true? how does that work?
Johnnydc
01-15-2011 10:18 PM
g23_ej1
05-26-2008 04:12 AM
o0ohaviko0o
04-18-2008 06:27 AM
Dhrcer
12-11-2007 10:39 PM
rezneffix
05-16-2007 09:54 PM
Quick Reply: putting ac into a 98 ek coupe gsr swap
