putting ac into a 98 ek coupe gsr swap
Re: putting ac into a 98 ek coupe gsr swap
do you still have the gsr a/c bracket bolted on? if not go grab a vtec delsol a/c bracket or its much cheaper counter part the crv b20 a/c bracket. and find a 96-98 d series a/c compressor. unless you wanna use a gsr a/c compressor in which case a gsr bracket and compressor and lines is what you want.
alright just making sure the ac compressor and condensor were from a 97 civic auto were the same.
318 Curves, 11 miles
On mine, I retained the entire D-series A/C system with the B20 bracket. The D series compressor should bolt up to the B20 bracket and everything will line up like OEM. This is because, if you've ever seen a CRV, it uses a D-series compressor on a B-series engine.
im thinking about putting a gsr swap into a 00 civic coupe and thought i needed the gsr ac bracket but read this and seen i need a b20 bracket?? is that true? how does that work?
Johnnydc
01-15-2011 10:18 PM
g23_ej1
05-26-2008 04:12 AM
o0ohaviko0o
04-18-2008 06:27 AM
