Heater doesn't work!?
Old 11-18-2009, 08:12 PM
Homotor's Avatar
Default Heater doesn't work!?
i have a 92 honda civic, and my heater is not blowing hot... a/c and everything else works and blows fine but when i change it to hot to blow heat it just blows air... can someone tell me what might be wrong?? thanks...
Old 11-18-2009, 08:41 PM
jdm602's Avatar
Default Re: Heater doesn't work!?
the cable that goes to the valve on the heater hose in the engine bay or under the dash may have come off. go check.
Old 11-18-2009, 11:04 PM
H_Bliss's Avatar
Check your thermostat. 99% of the time, it's that. And it's also a very quick and easy fix.
Old 11-18-2009, 11:37 PM
fastrxu's Avatar
The coolant thermostat? ^^^
Old 11-19-2009, 11:38 PM
Homotor's Avatar
ive checked the cable it seems to be connected and working, just no heat?? i will try changing out the thermostat if that doesn't work im out of options, thanks for your help guys...
Old 11-20-2009, 05:02 AM
kyden's Avatar
you might have a blocked heater core.
as for the thermostat, does the engine come up to normal temp?
Old 11-20-2009, 06:00 AM
fcm
Old Fart
fcm's Avatar
Ditto the above^^^.
If engine temp is OK it is either a restriction or the valve is not working, easy enough to check.
Once engine temp is up to normal, feel both the heater core hoses when heat is on, both hoses should be hot, if there is room check hose temp on both sides of valve, if one side is hooter/cooler then other side, replace the valve, [it's defective].
If heater core is plugged you may be able to flush it out, disconnect both heater core hoses and connect up a garden hose to the heater cores return side and turn on the water and flush out the core, you can even "break" stuff free by switching the garden hose back and forth between the inlet and outlet of the core. 94
DjSoulTrane
10-30-2011 03:06 PM
integradc4_rg87
10-29-2010 11:51 PM
smurf357
04-09-2010 10:38 AM
mrspeedy69
13
11-19-2009 06:30 AM
crxtreme27
14
04-21-2003 03:01 PM
Quick Reply: Heater doesn't work!?
