Honda Fluids vs others
Old 10-27-2009, 03:10 AM
Jordanasm's Avatar
Default Honda Fluids vs others
hey guys, I'm about to do a brake fluid change, change my mtf, and top off my other fluids. Do you think that Honda fluids are really "better" then lets say some other companies?
Old 10-27-2009, 05:16 AM
honda.lioness's Avatar
Default Re: Honda Fluids vs others
Here is my view based on years of owning Hondas:
Brake fluid -- any high quality aftermarket brake fluid is fine.
Hydraulic clutch fluid -- see brake fluid above.
Manual transmission fluid -- Honda OEM bought from dealer. I would not rule out some of the recommendations for other MTFs here, though. I would never use motor oil in the transmission; use of motor oil is outdated due to industry changes in motor oil additives.
Power steering fluid -- aftermarket stores like Autozone, Pep Boys and Napa sell a Honda specific PS fluid that is fine. Just make sure the aftermarket fluid container says it is for Hondas. Failing to get the Honda specific fluid can destroy the seals on the PS system.
Coolant -- either Honda OEM or orange Havoline Dexcool. The Dexcool says it is specifically designed for aluminum yada engines requiring yada. I have been using the Dexcool since 2002. I buy the undiluted version and then add distilled water. Do not use tap water.
Engine oil -- any good motor oil appropriate to the age of the engine is fine.
Old 10-27-2009, 07:05 AM
Jordanasm's Avatar
^ thank you.
Old 10-27-2009, 07:54 AM
CerealKiller's Avatar
Very well put.
Old 10-27-2009, 10:31 AM
New User
djblive's Avatar
I'll always use Catrol 5 30 or 5 30 highmileage
Old 10-27-2009, 03:41 PM
ajpturbopittsburgh's Avatar
I believe amsoil fluids are much better than OEM fluids. Go to their site and look at the specifications for the fluids. The temperature thresholds and most of the results from the tests prove them to be better.
Honda is not a fluid company, Amsoil, Royal Purple, Castrol, etc. are
The test results that AMSOIL displays are by third party I believe.
Old 10-29-2009, 04:37 AM
Retribution's Avatar
Honda doesn't make their own fluids, the fluids are made by fluid companies and put in a bottle that says honda.
Old 10-29-2009, 06:53 AM
Occupy GDD
Alex_G's Avatar
For most drivers off the shelf fluids will allow your vehicle to last a long time. If you plan to drag/auto-x/boost your vehicle AMSOIL fluids would be an excellent choice.
Old 10-29-2009, 03:34 PM
ChargedSI's Avatar
I would agree. If your not slamming the motor for gross performance, OEM fluid would be just fine and save you a ton of money.
Dennis T
Transmission & Drivetrain
07-10-2011 10:41 AM
Guimba
Suspension & Brakes
02-17-2010 06:05 PM
vdg721
10-25-2007 12:30 PM
Elvis1977
07-24-2007 11:49 PM
InfamousRS
05-12-2002 10:05 AM
Quick Reply: Honda Fluids vs others
