2001 civic power door lock fuses?
Old 09-12-2009, 09:50 AM
Shaynepolevault's Avatar
Default 2001 civic power door lock fuses?
i have a 2001 civic lx, my power door locks do not work. When ever I click the button I here a click that comes from under neath the dash, im assuming thats the relay. So where are all the fuses and relays associated with the power door locks? I want to check those before i go and buy a new switch. So please help thanks.
Old 09-12-2009, 10:17 AM
Default Re: 2001 civic power door lock fuses?
I did read that it dosnt have any related to power door locks on it. I looked through it twice and there was nothing. So if you know where the fuses or relays for the power door locks are let me know? thanks
Old 09-12-2009, 12:22 PM
no body knows what fuses and relays go to the door locks
Old 09-12-2009, 08:30 PM
WOW im sorry I was looking at the fuse diagram in the car, not under the hood. feel like an idiot. Ok so my door lock fuse is good, and when I push the door lock button in my car the relay under the dash makes 2 clinking noises, but my locks dont move. So does this mean I need a knew actuator, or new door lock switch? I want to get these working let me know thanks.
Old 09-13-2009, 09:28 AM
also to go along with i wrote above. What is a good way that I could test the actuators on my doors to see if they are good? Because bothe passenger and driver dont work so it makes me think that its not the actuators but I want to test them to make sure.
Old 09-13-2009, 05:15 PM
Icon2 test 2001 civic door lock actuator
How could i test my door lock actuator? When i click the lock button it makes a click sound under the dash but nothing happens, all fuses and relays are good. so i wanted to know if i could test the actuator? let me know thanks.
Old 09-14-2009, 02:15 PM
90sedan's Avatar
To test the actuator, hook direct power to it. Do this by disconnecting the 2-pin connector and applying leads to the pins, reverse polarity to change direction of the actuator. If no movement of the power door lock occurs than it will need to be replaced.
I would also test to make sure power is getting to the actuator. Test for voltage at the 2-pin connector on the harness when the switch is pressed.
9/10 times the actuator's are faulty and need to be replaced.
Old 08-20-2013, 01:08 PM
astateofmind's Avatar
Did you fix it after all? What was the problem?
SubwayH23
08-02-2018 04:09 PM
bpenner
06-25-2018 03:53 PM
kornerk12
03-17-2009 05:49 PM
azgreg
04-09-2008 01:04 PM
JMod
08-17-2003 05:38 AM
Quick Reply: 2001 civic power door lock fuses?
